Hatch Cover Flies Up
Old 06-11-2012, 06:50 PM   #1
bkgoetz is currently offline
My Model: 1998 Z212 Shabah 5.0L Bravo
Send bkgoetz:
Default Hatch Cover Flies Up
Don't know if anyone else has experienced this. When trailering, my rear hatch flies open, say around 35 MPH. The stingy little straps on each side are almost useless. They pop right out. I suspect air gets under it on the ends between the saet back and the sides of the boat. Only way I can tow is with all the covers on. Hate those snaps after a long hot day. Anyone have any ideas.
BG
  • Old 06-11-2012, 07:43 PM   #2
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Default Re: Hatch Cover Flies Up
    Did you try closing the center windshield? It will cause a lot less turbulence inside the boat. If that doesn't work, run a tie down strap from the ski hook to something inside the boat to hold er down. Good luck,
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Thank you DCB_MINDED for this useful post!
    bkgoetz (06-12-2012)
    Old 06-12-2012, 05:05 PM   #3
    Send bkgoetz:
    Yeah, I tried closing the center windshield, didn't help. I can lash it down with a ratchet strap, but I was hoping for something a little more elegant. Just wondering why I seem to be the only one with this problem.
    Old 06-12-2012, 08:23 PM   #4
    DCB_MINDED's Avatar
    Send DCB_MINDED:
    Mine has gas shocks mounted underneath, they seem to hold a little pressure on it.... but then again, I don't think Chuck Norris could lift mine without assistance from the shocks!
    Old 06-13-2012, 12:28 PM   #5
    Send bkgoetz:
    Mine has shocks also, but you're right, it would be pretty hard to lift without them.
    Old 06-13-2012, 01:16 PM   #6
    caraudio91 is currently offline
    My Model: 212z
    My Engine: 350/alpha one
    Send caraudio91:
    mine did that too, i put a lockable hatch handle on mine so i know its locked
    Old 06-13-2012, 05:51 PM   #7
    theeasynine's Avatar
    My Model: z240 Talari
    Send theeasynine:
    I would replace the snaps they are probably worn out. Mine snap tight and stay connected. Definitely want to keep it secured though somehow.
    Patrick
    Old 06-13-2012, 06:55 PM   #8
    Send bkgoetz:
    It's done it since day 1. Thought about maybe replacing the snaps with something more positive. Just not sure how much pressure is being exerted and I don't want to risk ripping something apart.
    Old 06-13-2012, 06:57 PM   #9
    Send bkgoetz:
    Hey caraudio91...what did you use for a handle and where did you attach it?
    Old 06-13-2012, 07:09 PM   #10
    mosky's Avatar
    mosky is currently offline
    My Model: 202
    My Engine: 5.0L Alpha
    Send mosky:
    Do you have a cover for the bow area?
    My dealer years ago advised me that i shouldn't tow the boat on the highway without this cover on and the windshield closed as he had experiences with the hatch cover flying open when he forgot to do either one of those.
    With both of those done the air will only enter the boat around and over the windshield which should not be direct enough to lift the hatch cover even without the snaps attached.
    Fuel tank inspection hatch cover feels spongy RMBIGDOG Original Mariah Talk 8 05-11-2012 01:37 PM
    Gas Struts for hatch spinks99 Projects 7 05-06-2011 12:05 AM
    Power engine cover/hatch NogginDoc Boating 101 1 07-19-2010 07:17 PM
    Power engine hatch cover pics karmann Original Mariah Talk 0 05-09-2009 02:36 AM
    Towing Cover - Mooring Cover 22empire Trailering and Tow Vehicles 1 04-13-2009 08:57 PM
    There are 280 users
