first time out
Old 05-20-2012, 12:17 AM   #1
TAT Thread Starter
TAT is currently offline
My Model: z192 Barchetta
My Engine: 4.3L LX
Send TAT:
Default first time out
well today was my first trip on the water. I started he boat up at the house before we left, got to the lake backed her down the ramp, unloaded, pulled the truck and trailer out, my wife, son and got in, went to start it and nothing. Thankfully another boater was there to lend me his battery to jump mine. Boat fired right. Off we went.
She ran great! I was impressed, this is my first mariah. I topped out at about 50mph turning 2500rpm.
  • Old 05-20-2012, 01:19 AM   #2
    Default Re: first time out
    If u topped out at 50mph at only 2500rpms then something is wrong with your tach. At 50mph with that 4.3 you would have somewhere around 4800-5000 rpms. And know that boat speedos are nearly always optimistic so if you want an accurate reading then use a GPS. Other than that, i'm glad to hear the rest of your first day on the water went well.
    Assuming you were correct in the reading that usually can easily be fixed. Access the backside of your tach & you should see a small wheel marked 2-4-6-8. Give the wheel a spin a few times then reset it at 6 (for 6 cylinder).
    Old 05-20-2012, 02:27 AM   #3
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    They will almost always start at home.... But never when you get to the water....LOL A battery maintainer and a spare battery are a must in my opinion.
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 05-20-2012, 12:42 PM   #4
    TAT Thread Starter
    My Engine: 4.3L LX
    Send TAT:
    Yeah, of course they always start at home. I was talking to another boat owner on the lake he suggested a two battery system, any thoughts?
    Thanks for info mickeyt. I found a thread last night explaining rpm at WOT. I will rest it today.
    I do not have an owners manual for this boat, but is there a choke position? On my other boat it was all the way back.
    Old 05-20-2012, 03:43 PM   #5
    DCB_MINDED's Avatar
    Send DCB_MINDED:
    I have 3 in my boat.... Just, but I run a lot of toys..... There are several different types of setups. The best uses a switch that will switch between Battery 1, Battery 2, or both. As well as an isolator that allows the engine to charge both batteries. You can get by without the isolator, but you have to switch manualy to the battery that you want to charge.
    Also, the choke should be automatic.
    Old 05-20-2012, 10:54 PM   #6
    TAT Thread Starter
    My Engine: 4.3L LX
    Send TAT:
    DCB_minded thanks for info. I will look into a two battery system.
    Mikeyt, you were right about my tach it was not even set for a 6. I changed it today now we will see what i am really turning. you said i should be between 4400 and 4800 and wot right?
    Old 05-20-2012, 11:33 PM   #7
    DCB_MINDED's Avatar
    Send DCB_MINDED:
    Yes, 4400-4800 RPM is the correct WOT range for your engine. You can tell a while lot about your prop by looking at this number. RPM too high, you need a steeper prop.... Too low, you are over-propped and your holeshot and overall performance of the boat will suffer.
    Old 05-21-2012, 01:47 AM   #8
    TAT Thread Starter
    My Engine: 4.3L LX
    Send TAT:
    Thanks for info. I will keep that in mind while on the water again. I currently have a 3 blade prop not sure of pitch. I have read where many have gone to a 4 blade prop. I wanted to ski yesterday to see how she would pull me out of the water, but my wife was not comfortable driving it yet.
    Old 05-21-2012, 01:52 AM   #9
    A 19" 3 blade or a 20" 4 blade will easily handle skiing/wakeboarding/tubing duties with your setup. I've got a 20" - 4blade SS on mine but lots of members with the 18-19' & 4.3 run the 19" prop. Either of those props will have you running right at 4800-4900 rpms at WOT which is just about perfect.
    Old 05-21-2012, 07:40 PM   #10
    TAT Thread Starter
    My Engine: 4.3L LX
    Send TAT:
    Thanks for info mikeyt. I plan to get out this weekend to see where my rpms really are.
    Well went out for first time alliedasset Boating 101 1 05-16-2012 05:27 PM
    First Time out ! Atec Boating 101 2 08-17-2011 06:52 AM
    First Time Out.......... wcso909 Chit Chat/Off-Topic 4 07-07-2011 05:51 PM
    About time............. Boatcrazy Original Mariah Talk 10 08-05-2009 09:43 AM
    The very first time Mark Anderson Boating 101 2 09-29-2008 10:53 PM
    Total Members: 18,995
    Total Threads: 13,326
    There are 272 users
