Winterized for 2 years
Old 05-08-2012, 08:40 PM   #1
jjk61083's Avatar
jjk61083 is currently offline
My Model: 202 Shabah
My Engine: 5.0L Alpha One
Send jjk61083:
Default Winterized for 2 years
I bought my 98 Shabah 202 in May of 2010 and used it quite a bit that summer. I had it winterized by my boat guy and put inside a storage building. My daughter got married last summer so we left the boat in storage for financial reasons. I'm getting ready to bring it home again soon and went by to talk to the guy who winterized it to see if I needed to do anything different this year. He said we needed to drain the fuel and he would make sure it starts and runs ok. Has anyone experienced this before - and has it caused any other problems? It was in perfect running condition when we put her to sleep. Thanks.
Jim
1998 Mariah 202 Shabah
5.0 Alpha One
  • Old 05-08-2012, 08:52 PM   #2
    rayzorback's Avatar
    My Model: 210 LE
    My Engine: 454 Bravo 1
    Gallery Images: 10
    Send rayzorback:
    Default Re: Winterized for 2 years
    Should be fine with new fuel.
    Old 05-08-2012, 09:18 PM   #3
    Minnox's Avatar
    Minnox is currently offline
    My Model: Z 235 Talari
    My Engine: 5.7L Bravo III
    Send Minnox:
    The fuel tank should be emptied and the carburetor may need attention and possibly replace the batteries. You also should check (yearly if not more often) your bilge pump fuel lines and any thru hull fittings as a safety concern. Just my 2 cents.
    Mike
    1996 Z235 Talari 5.7L Bravo III
    Upper Chesapeake Bay Is My Playground!!!
    Old 05-08-2012, 10:32 PM   #4
    The mechanic isn't being unreasonable although if you put fuel stabilizer in the tank back and properly winterized the engine in the fall of 2010 you may not have to empty what is there, just fill it up with fresh fuel. You also might want to watch for any signs of overheating due to a failed impeller though. Depending on how the batteries were treated while in storage (or did you remove them?) they may simply need to be topped up. Having the mechanic just start her up & give it a quick check over may be a good thing.
    Old 05-10-2012, 05:10 PM   #5
    jjk61083's Avatar
    Send jjk61083:
    Thanks, guys. I did remove batteries and have them stored in my basement. I will be putting them on a charger this weekend. Getting excited about just hooking her up and pulling home tomorrow.
    Jim
    5.0 Alpha One
    Old 05-16-2012, 05:02 PM   #6
    jjk61083's Avatar
    Send jjk61083:
    OK-just an update. Took the boat in yesterday and had the fuel drained, levels checked and everything looked over. Started and ran great - ready for the lake. Planning on going out Memorial weekend.
    Jim
    5.0 Alpha One
    Boat has sat for 2 years? What to do? lmuearl General Maintenance 3 01-02-2011 10:47 PM
    Boat has sat for 2 years? What to do? lmuearl Boating 101 0 12-24-2010 05:19 AM
    3 Years Old! mikeyt Chit Chat/Off-Topic 9 07-19-2010 01:42 AM
    Mercruiser 4.3 been sitting for 5 years firebirdzig Mercury MerCruiser 4 06-12-2010 03:35 PM
    owned for years but new to site MariahMX20 Introductions 3 04-17-2008 12:14 PM
    There are 259 users
