over heating z302/7.4
Old 04-22-2012, 07:16 PM   #1
GlennGeng is currently offline
My Model: z302st
My Engine: volvo 7.4L
Send GlennGeng:
Default over heating z302/7.4
I changed the risers and manafolds, checked flow of pumps.Boat stays cool at low rpm and idle. When take it over 2k rpm, motor quickly over heats. Looking for answers. Tks Glenn
  • Old 04-22-2012, 09:10 PM   #2
    Default Re: over heating z302/7.4
    Drive Impeller , engine water pump , thermostat stuck , blockage in system. I'd check those first.
    Larry
    Old 04-23-2012, 04:13 PM   #3
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    How did the temp look before you changed the risers and manifolds and why did you change them? Is this engine fuel injected or carb? Are you doing this test in the water or on the trailer with muffs while hooked to a water hose? Does the temp go up only under load or also while revving the engine while out of gear? Are all hoses routed properly? What type of exhaust do u have, are they above the water line where u can actually see water coming out of them? Check these things first and let us know what you find? There are some other things that can cause overheating like fuel air mixture, ignition timing, etc but make sure all water is flowing properly first. I know these are more questions than answers, but I hope it gives u a starting point.
    Happy Boating
    Dan
    1995 Z272 Barchetta
    Z302 Cushions woodward33 Original Mariah Talk 7 11-17-2012 01:42 AM
    Z302 for 12k Boatcrazy Mariah Boats For Sale & Wanted 1 07-08-2010 04:31 PM
    sad to see our z302 go! tobaccogrower Original Mariah Talk 2 09-30-2009 01:36 AM
    Heating / Overheating question karmann Original Mariah Talk 10 06-25-2009 07:52 PM
    99 Z302 on eBay WetWilly Mariah Boats For Sale & Wanted 0 04-17-2008 07:12 PM
    There are 234 users
