Purchased a bunch for goodies for my Shabah 222
Old 05-02-2012, 11:43 PM   #21
DCB_MINDED's Avatar
My Model: Shabah 238
My Engine: 5.7 Alpha1
Send DCB_MINDED:
Default Re: Purchased a bunch for goodies for my Shabah 222
Sounds like you are running on low voltage. You need to check your alternator to see if it's charging, and have your batteries tested as well. If the alternator is charging properly, you SHOULDN'T have the RPM issues, even with a dead battery..... but DC voltage will do funny things (especially when bad grounds are involved)
'99 Mariah Shabah 238
5.7 Thunderbolt w/Alpha1
  • Old 05-03-2012, 04:11 AM   #22
    Dsg03svt is currently offline
    My Model: Shabah
    My Engine: 5.7 Mercruiser
    Send Dsg03svt:
    Correct me if I'm wrong, but I'm thinking that the problem with the low rpm radio issue was due to the fact that I only has the switch always in the "1" position. This would mean that only the "1" battery would charge by the alternator. However, now with the boat having ran in the "all" position, I would think the battery 2 would have enough juice to operate correctly in any position.
    Thanks.
    Old 05-03-2012, 04:19 AM   #23
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    Thanks.
    I think your battery 1 is kaput! Now that you have joined the second battery you have enough juice to power everything. the ill effect of this is that you have no spare battery to fall back on if they both die.
    Since I dont know what your wiring system looks like it just sounds suspicious. I agree with DCB_MINDED, you should have your batteries and ALT checked out. If you have access to a clamp meter you can check the ALT to see what its pushing (AMPS).
    2001 Mariah Shabah Z222
    Old 06-03-2012, 04:21 PM   #24
    Chris B. is currently offline
    My Model: Z222 Shabah
    My Engine: 7.4L MPI, Bravo I
    Send Chris B.:
    So has the tower went on yet? I am about to install a tower on my 98' 222, so I am looking for lessons learned.
    Purchased a PC-7424XP to Shine Up the Mariah Dsg03svt Original Mariah Talk 12 05-13-2012 03:55 PM
    Wanted: WANTED: Mariah Goodies surbski Mariah Parts For Sale & Wanted 4 07-06-2009 10:55 PM
    There are 380 users
