Transom mount transducer... or other style?
Old 07-26-2011, 01:36 AM   #1
nglauer's Avatar
nglauer is currently offline
My Model: 180 Diablo
My Engine: 3.0L Alpha one
Send nglauer:
Default Transom mount transducer... or other style?
Well....
I was going to install my Lowrance LST-3800 this weekend, but i'm still unsure about mounting my transducer. I have a transom mount unit and am leary about adding more holes to my boat (after adding smart tabs). I'm also unsure about the cable routing. I noticed a few mounted online, that had a clamshell/escutcheon cover that went over the hole. It looked as if the hole was filled with some type of marine adhesive.
Does anyone have any personal opinions on these? or pictures of how your transducer is mounted?
Which is more effective? Transom mount or thru-hull?
I want the water temp and depth to be as accurate as possible.. and am concerned that the smart tabs and prop could cause turbulence if I use the transom unit back there.
Again, any opinions are greatly appreciated.
Nick
    Transom Mount vs. Shoot Through Hull Transducer dwymer64 Sea Fox - Mariah Talk 11 03-23-2015 06:20 PM
    I need a picture of Smart Tabs, and Transom Mount Transducer on a Mariah nglauer Original Mariah Talk 4 06-24-2011 07:13 PM
    Hocky puck style depth finder joeboat Original Mariah Talk 1 06-06-2011 01:56 PM
    font style on Jubilee upholstey Gunner Original Mariah Talk 2 09-30-2009 01:05 PM
    There are 296 users
