Smart Tabs and Stingray
Old 06-25-2011, 10:39 PM   #1
Double D's Avatar
Double D is currently offline
My Model: 98 Mariah 202 Shabah
Send Double D:
Default Smart Tabs and Stingray
Does anyone run Smart Tabs and a Stingray fin? What would be the best, could a guy run both?
  • Old 06-25-2011, 10:41 PM   #2
    Default Re: Smart Tabs and Stingray
    No one in their right mind would do something like that. Using a Stingray fin is stupid enough all on its own.
    Old 06-25-2011, 10:52 PM   #3
    Double D's Avatar
    Send Double D:
    Sorry just wondering, could you tell me why stingray are bad, I see alot of boat with the on. Please help was thinking about either one.
    Old 06-26-2011, 03:04 AM   #4
    Drilling 4 holes in your cavitation plate to mount the Stingray can eventually lead to damage to the outdrive. The holes weaken the plate & with the added stress of the hydrofoil it can lead to failure (read....new outdrive). I've personally seen this happen now on 3 occasions. Now i know we have a few members here with them mounted. They do improve the planing ability of your boat but they can also negatively affect the stability of your boat at high speeds. Its your call since its your boat.
    The Smart Tabs do everything the Stingray can do and do it much better without the potential to cause problems. Do a site search for Smart Tabs and you will find 9 out of 10 members here love them. Your 202 would likely require the Smart Tabs SX with 80# actuators or possibly the S.S. version. I'm pretty sure there are a couple of other 202 owners here that have them mounted so maybe they will chime in.
    Old 06-29-2011, 04:54 PM   #5
    anguspoe is currently offline
    Gallery Images: 1
    Send anguspoe:
    I have a Stingray on my 180 i been a little lazy to remove not knowing it could cause damage.
    The 4 holes, leave them open or fill them? if so fill them with what?
    Old 06-29-2011, 06:59 PM   #6
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    The quick fix I have seen is JBweld I would suggest aluminium weld them then sand and repaint won't know they were ever there. Just my opinion
    darkcalling
    Z 278 Limited
    Old 06-29-2011, 07:48 PM   #7
    JB Weld will do the job or aluminum filler that you can pick up at most automotive stores.
    Smart tabs SX on 180? ryker137 Sea Fox - Mariah Talk 2 07-26-2011 10:41 PM
    smart tabs Oregondunes Projects 0 03-14-2011 04:09 PM
    smart tabs?? tazzyou Original Mariah Talk 11 02-06-2011 12:03 AM
    Smart Tabs cometb Original Mariah Talk 4 07-02-2010 09:35 PM
    There are 206 users
