Z302 Shore Power Connection
Old 06-20-2011, 04:07 PM   #1
mona.porche is currently offline
My Model: c302
My Engine: 7.4L bravo iii
Send mona.porche:
Default Z302 Shore Power Connection
How can you make the outlet in the back of the boat connect to shore power? We can only use the one on the side and it is on the opposite side of the post. Is there a particular adaptor that can be used for the back?
  • Old 06-20-2011, 04:15 PM   #2
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: Z302 Shore Power Connection
    Shore power cord?
    I have no idea what either of those questions mean. The one what? On the opposite side of what post? The back of what?
    Jim
    “The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
    Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
    Old 06-20-2011, 06:56 PM   #3
    The plug on the transom of the boat is a 3-prong 110v AC plug that is specifically for the battery charger. You can't use it to power the shorepower system.
    You could have the battery charger wired into your shorepower system, if you wanted to eliminate the rear plug in port (and the need for 2 different cords). But I will recommend having it done by a professional marine electrician. Boating electrical systems can get rather complicated and can cause many hazards and damage if not done properly.
    However if you want to not use the shorepower hookup port on the boat, there is an adapter you can buy to convert shorepower to a standard 3 prong hookup. I use one for mine, since my boat doesn't have shorepower. This is what it looks like, it plugs right into my dock hookup, and I just use a long insulated extension cord to connect it to the battery charger port on the transom.
    They're available at West Marine or any other boating retailer. Hope this helps.
    mona.porche (06-20-2011)
    Old 06-21-2011, 05:47 AM   #4
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    both of mine are wired together. Make no difference which plug is hot, there is juice at either end. surprise me once thats for sure.
    2000 Z302 Bow Rider
    Thank you Oregondunes for this useful post!
    mona.porche (06-21-2011)
    Old 06-21-2011, 12:15 PM   #5
    My Model: c302
    Send mona.porche:
    Did you use an adapter for the back connection?
    Old 06-21-2011, 02:47 PM   #6
    Gallery Images: 36
    Send Oregondunes:
    I dont know. I didnt do it. I can tell you that when either plug in are connected to 115v the other is hot too.
    I have not tried to use the micro with the rear connection only, but I would figure it could handle a 20a connection just fine.
    2000 Z302 Bow Rider
    shore power tazzyou Original Mariah Talk 7 04-03-2011 11:37 AM
    Shore Power or Inverter the Problem? Z280Bob Original Mariah Talk 1 10-11-2009 11:19 PM
    Shore power question Merrick6917 Original Mariah Talk 1 05-25-2009 05:25 PM
    shore power huj Original Mariah Talk 1 05-03-2009 01:57 AM
    shore power hookup on a 96 z255 Jeff Barnett Original Mariah Talk 5 09-06-2007 06:26 AM
    There are 301 users
