shore power hookup on a 96 z255
Old 09-05-2007, 06:46 AM   #1
Jeff Barnett is currently offline
Status: In Limbo
Gallery Images: 1
Send Jeff Barnett:
Default shore power hookup on a 96 z255
Hi folks.
I've never connected the shore power on my 96 z255, however I'd like to.
I'm just wondering what the deal is. my hookup is on the port side, and inside the cuddy on the port side is one double plug GFI outlet with an on off switch. Question. is this the extent of shore power? one outlet? or am I missing something here. does it provide power to any other systems? is there a switch to go from DC batterys to shore power??
Help
Jeff
  • Old 09-05-2007, 12:08 PM   #2
    Hi Jeff, your shorepower package, if it is factory installed, should look like the picture below. There should be a GFI switch, polarity indicators, and switches if you have any other accessories that run on AC. ie refrigerator, microwave, battery charger, tv, etc. There should also be a main switch to turn the shorepower on and off. Essentially, that's it.
    On larger cruisers, they use shorepower to run air conditioning, onboard water systems, galley accessories, etc. It's a nice feature, but it only works when you're hooked up at the dock.
    Old 09-05-2007, 02:53 PM   #3
    Status: In Limbo
    Gallery Images: 1
    Send Jeff Barnett:
    Thanks for the reply Chris. Mine only has the outlet, with an "on/off" breaker type switch. non of the other stuff. I can post a picture a little later.
    Jeff
    Old 09-05-2007, 11:02 PM   #4
    Status: In Limbo
    Gallery Images: 1
    Send Jeff Barnett:
    Hi Chris, here is a shot of my "shore power panel" it looks factory, just pretty basic..
    Old 09-06-2007, 12:23 AM   #5
    Yep, that's factory. I think they redesigned the shorepower interface around 97-98 when they went to the new dash design. Thanks for posting the pic. It's nice to see how things change through the years.
    Old 09-06-2007, 06:26 AM   #6
    MariahMan's Avatar
    Status: Admin Guy
    My Model: 252 Shabah
    Gallery Images: 211
    Send MariahMan:
    To answer your initial question Jeff, yeah, looks like your shorepower only powers that one outlet.
    That's a pretty lame setup from Mariah. When my dad and i redesigned our electrical system to install dual batteries and a main selector panel that also combines the batteries in emergencies, we thought about adding shorepower. We wanted it so that when plugged in, the entire boat would run off the shorepower rather than the batteries. That's how i think it should be. We realized that we are never at docks w/ shorepower anyways so decided not to worry about it.
    Let me know if you decide to reconfigure the setup to make better use of the shorpower rather than being limited to one plug. I have some diagrams i made up for our install that may help you out w/ setting up the system.
    -Ryan
    ThunderShark Web Solutions
    Power deck lid Assembly?? '93 Shabah 212Z Rick Original Mariah Talk 6 03-31-2008 05:26 PM
    Problem w/ power engine cover joe2106 Original Mariah Talk 6 12-28-2007 04:12 PM
    Power ram for engine cover 97 Z222 Original Mariah Talk 2 11-12-2007 09:56 PM
    Clean way to charge batts when shore power is avail. Jeff Barnett Boating 101 0 09-17-2007 09:31 PM
    For Sale: Mariah Power Seat Slider, eBay, almost over! 215Talari Mariah Parts For Sale & Wanted 0 07-24-2007 08:42 PM
    There are 330 users
