Not the usual RPM question
Old 06-29-2011, 04:55 PM   #11
sanukc's Avatar
sanukc is currently offline
My Model: 205 Davanti
Send sanukc:
Default Re: Not the usual RPM question
Originally Posted by Reulandjr View Post
Each 1" drop in pitch increases RPM by about 200, so if you're really running at 3500 you should be running at about 4500, but I can't believe you're actually running a 19" and gettingn3500 RPM. CHECK it again, but my 222 with a 350 mag mpi came with a 19" prop and imwas turning about 4500'RPM
I verified it to make sure it was a 19 prop. Attached is a pic. I wonder if it was because it was fully loaded with 5 people with a full tank of gas. photo.JPG
  • Old 07-01-2011, 06:32 PM   #12
    sanukc's Avatar
    Send sanukc:
    I tested it again today with just my wife and I on the boat with a full tank of gas. WOT was 34mph @ 4000 RPM. Cruising was at 24mph @ 3000 RPM. Both speed measurements on the speedometer since I don't have a GPS yet.
    Sanu
    Old 07-02-2011, 12:25 AM   #13
    voodoo's Avatar
    voodoo is currently offline
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    My new to me boat, Davanti 225, 5.7 had a stainless 14x19 3 blade. ran poorly and had a hard time getting on plane. A couple of time she wouldn't. 3 people and a fat dog full fuel load. 4200 rpm max at 42 mph.
    New plugs, one was much darker than the other 7, new cap and rotor. New 14x17 4 blade.
    Whole different boat. Planes in a couple of seconds, reaches 4600 rpm at 45 mph.
    Question, what is the red line of the motor, as she will continue to gain revs past 4600 rpm with the 17 inch prop?
    Gonna try the 19 again, maybe buy an 18.
    Old 07-02-2011, 03:50 AM   #14
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Red line most gm engines is 5 grand stock the 496 I think is 5200 your wot should be between 4000-5000rpm 4600 would be a safe place to be going much over you are near the limit.
    darkcalling
    Z 278 Limited
    There are 259 users
