Raising the outdrive?
Old 08-27-2009, 01:41 PM   #1
GageCreasy is currently offline
Send GageCreasy:
Default Raising the outdrive?
I just bought my first Mariah, and for the life of me I can't find the outdrive lift to trailer it. My last boat had a button on the drive itself, HELP!!!!!
Thanks guys.
Gage
  • Old 08-27-2009, 02:19 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: Raising the outdrive?
    What model year boat, engine and drive combo do you have. The correct answer to the question will require this information.
    I have the quicksilver 3000 throttle control on mine, and the trailer trim button is a small rubber pad in the lower right corner.
    My Mariah
    Old 07-01-2011, 02:42 AM   #3
    bobcatdad48 is currently offline
    My Model: Z220 talari
    My Engine: 5.7 Bravo 3
    Send bobcatdad48:
    On my mariah it is built into the housing around the throttle and is hard to see. It is located on the lower right corner of the housing. You have to push hard to get it to work. Hope this helps.
    Old 07-02-2011, 12:22 AM   #4
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    As Z202 stated, we need to know which model boat you have and which throttle. On mine, the trailer button is part of the trim. I push the trim button in one click to trim up and push in further for second click and that is the trailer function. It took me a very long time to figure that out. I kept looking for a second switch!
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Outdrive 96blackmariah Original Mariah Talk 6 06-22-2009 04:11 PM
    raising my deck lid paulbroeder Original Mariah Talk 3 06-16-2009 05:58 PM
    Refinishing the Outdrive bdbyrnes Projects 2 04-16-2008 05:43 PM
    Vibration from Outdrive? dudders Mercury MerCruiser 10 01-13-2008 04:09 AM
    Outdrive Play? Jeff Barnett Mercury MerCruiser 2 09-19-2007 07:34 PM
    There are 334 users
