Screw Cover replacement.
Old 05-05-2011, 04:46 PM   #1
plenty is currently offline
Send plenty:
Default Screw Cover replacement.
Does anyone know the correct taylor made product number for the vinyl screw cover I need for a 1996 talari? The product list recemmends waterbonnet.com - which is no longer in business. Taylor made has sent me several samples, none of which are the correct product.
Please help.
  • Old 05-05-2011, 05:37 PM   #2
    Default Re: Screw Cover replacement.
    I think that when i replaced my foam windshield screw cover a few yrs ago, i simply went to the local Lowes/Home Depot store and found some winter draft stop stuff that was the right size & shape.
    Old 05-05-2011, 06:30 PM   #3
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    if you are talking about the plastic colored screw caps, try your local stereo shop.
    2000 Z302 Bow Rider
    Old 05-06-2011, 12:43 AM   #4
    Shabah 198SE's Avatar
    Shabah 198SE is currently offline
    My Model: Shabah 198SE
    My Engine: 5.7L Alpha
    Send Shabah 198SE:
    Please halp.
    plenty,
    1/2" x 3/4" x 6' = #1630
    5/8" x 1 1/4" x 8' = #1631
    Shabah 198 SE
    Old 05-06-2011, 03:56 AM   #5
    Send plenty:
    Thanks so much. So I am guessing there is no vinyl option, just the foam. I'll pick some up.
    Old 05-06-2011, 12:11 PM   #6
    180se is currently offline
    My Model: 180se shabah
    My Engine: 3.0 alpha I
    Send 180se:
    their is a vinyl replacement for the screwcover,I have the part number down at my place were I work on my mariah as soon as I get their I'll post the part number for you the vinly piece fits good,I tried it on my boat
    Thank you 180se for this useful post!
    plenty (05-06-2011)
    Old 05-06-2011, 09:08 PM   #7
    Send 180se:
    the taylor made part number for the 1/2 by 3/4 inch is 8229040 and the customer service number is 1-518-773-0636 and I talked to Gale,for the vinyl and they sell it by the foot, I hope that will help you.
    plenty (06-03-2011)
    Old 05-07-2011, 11:51 AM   #8
    Send plenty:
    Thank you very much.
    That happens to be the one product they did not send me a sample of because they were certain it was not the right one. I will call them to send out a sample.
    I'll keep you posted. Thanks again.
    Old 05-07-2011, 12:22 PM   #9
    Send Shabah 198SE:
    plenty,
    I do not know if it would fit a Mariah screw cover track, but I purchased, back in 2000, some hard vinyl snap in screw cover from Taylor Made (#833892). It was for my 1985 Sea Ray. My first concern with it, on your Mariah, is that it may not seat properly on your curved windshield. All of the sections on my Sea Ray were straight and flat.
    On my Sea Ray, where the screw cover slot tapered at the end, it was not a very secure fit because you lose a section of the snap in feature when you cut the cover for the taper. That product also dries out and shrinks. At one of its tapered ends, it even warped in the sun. If I had to do it again, I would go with one of the soft foam screw covers. I they shrink or get damaged, all you have to do is cut out the bad piece and insert a new section.
    Well, that is my $0.02.
    Good Luck
    Shabah 198SE
    Old 06-03-2011, 04:17 AM   #10
    Send plenty:
    8229040 is the correct vinyl screw cover for the 1996 Talari 215. Thanks to all who helped me track this down.
    Gas Cap Replacement brimerianzan Original Mariah Talk 1 09-07-2010 06:25 PM
    bellow replacement? lawmanbsi Original Mariah Talk 3 06-17-2010 11:15 PM
    Rear Seat & Sun Cover Replacement? samport Original Mariah Talk 1 06-05-2010 02:25 PM
    Towing Cover - Mooring Cover 22empire Trailering and Tow Vehicles 1 04-13-2009 08:57 PM
    Windshield screw cover gasket shoot001 Original Mariah Talk 2 02-17-2009 11:55 AM
    There are 407 users
