Stolen Outdrive
Old 05-04-2011, 07:13 PM   #1
otto is currently offline
My Year: 2005
My Model: Z 240 Talari
My Engine: 5.7 Bravo III
Send otto:
Question Stolen Outdrive
I have a 1995 Mariah Z 240 Talari Bravo III hull no MABxxxxxxxxx witch the outdrive was stolen . I need to replace but need the drive ratio and the prop numbers if anybody can help with Info.
Thanks Otto
Last edited by ShabahZ280; 05-04-2011 at 09:59 PM. Reason: removed hull id number for privacy
  • Old 05-04-2011, 07:51 PM   #2
    Default Re: Stolen Outdrive
    Send a PM to ShabahZ250 with your boat info including the hull#. We have the build sheets up to Jan 1995 so it may be contained there.
    Old 05-04-2011, 10:03 PM   #3
    Sorry, it was built after January 95, (March of 95 to be exact), so I have no build sheet info for you. Plus, the build sheet lists the motor and outdrive info, not the specific gear ratio. Sorry I couldn't be more help! I'm sure someone will chime in with the answer you need.
    Changing outdrive oil jballa24 Volvo Penta 5 10-14-2014 01:29 PM
    Raising the outdrive? GageCreasy Original Mariah Talk 3 07-02-2011 12:22 AM
    Where can I find an outdrive? jasfiveo Original Mariah Talk 3 07-15-2010 09:17 PM
    Outdrive shot....Help jasfiveo Original Mariah Talk 5 06-21-2010 05:44 PM
    Outdrive 96blackmariah Original Mariah Talk 6 06-22-2009 04:11 PM
    There are 259 users
