Gas Guage
I am not sure if my gas guage is working. I put 10 Gal in it when it was at a 1/2 of tank and it never moved. The next day I put in 15 Gal and it moved a little. Does anyone have any troubleshooting tips I can try. I am thinking with 25 Gal in 2 days i should have seen some movement on a 50 Gal Tank. Any help would be much appreciated. If the gas sensor in the tank is bad is that a costly fix if I have to take it somewhere?
Re: Gas Guage
Clean the electrical connections on the gauge end and the sender end - that usually resolves the issue. Use dielectric grease when you put them back together to avoid this issue in the future.
Re: Gas Guage
My Bilge pump will not stop running. Does anyone have any suggestions?
Re: Gas Guage
Either the manual switch is in the on position or the float is in the up position, or something wrong with the pump.
Only those two things should turn it on. |
Re: Gas Guage
Re: Gas Guage
thx. Jan |
Re: Gas Guage
| All times are GMT. The time now is 02:17 AM. |
