trailer for a 252 Shabah
Old 09-19-2010, 08:51 PM   #1
edward cossey's Avatar
edward cossey is currently offline
Status: Ed Cossey ( sonny boy )
My Model: 1998 Z252 Shabah Mercr
My Engine: 7.4L Bravo 111"
Gallery Images: 4
Send edward cossey:
Default trailer for a 252 Shabah
Hi guys
I am looking for a trailer for my 252 shabah. has any one gor an idea of the type and carrying capacity i will need to have.
Ed Cossey
  • Old 09-20-2010, 11:31 AM   #2
    MAJIC is currently offline
    My Model: 1997 Z252 Shabah
    Gallery Images: 9
    Send MAJIC:
    Default Re: trailer for a 252 Shabah
    I've been looking for a 6,500 pound capacity. Figure the boat is close to 5,000 plus stuff. That has to be tandem axle. I prefer roller trailers, but bunks are ok. You'll need to make sure the rollers or bunks are adjustable to fit the hull. I've tried a couple of fixed bunks (welded in place) and they didn't fit right.
    Good luck! New trailer is going to run $3,500-$4,000 (USD)
    MAJIC - Z252
    Old 09-20-2010, 09:16 PM   #3
    Gallery Images: 4
    Send edward cossey:
    thanks MAJIC
    I thought about 6500lbs. would i have to have a trailer for a V hull or do you adapt the trailer to fit. i have been looking at used trailers they seem to range at about $2000 to $2500. so maybe its best to by new just for the warrantee and reliability.
    thanks again
    Ed Cossey
    Old 09-23-2010, 03:54 PM   #4
    vegaskid is currently offline
    My Model: Shabah Z255
    My Engine: 454 - Bravo
    Send vegaskid:
    The trailer for my z255 was toast this year and had rusted out completely on the main and rear beams. The thing sounded like cardboard when you tapped it instead of steel. I took it to a local fab shop and they rebuilt the whole thing for about 1800.00. They used the axles, bunks, lights and anyother salvageable parts and the new trailer turned out great. Work is pretty slow right now and a couple of the Utah trailer manfacturers I called were wheelin and dealin. I had one of them, metal craft trailers get down into the 3100.00 dollar range for a bare bones custom made trailer.
    Old 09-23-2010, 05:01 PM   #5
    Gallery Images: 9
    Send MAJIC:
    my 2 cents: if you're going spend over $2,500 - go new. If you're more north than south, this is a good time of year to wheel and deal vegaskid found out as dealers need to clear inventory.
    Most trailers are setup for a v hull especially for boats this size. There are specific layouts for pontoons, catamarans, and flat boats (don't see many flats over 20' though...).
    MAJIC - Z252
    Old 09-26-2010, 10:49 AM   #6
    Gallery Images: 4
    Send edward cossey:
    Thanks Guys
    i looked on craig list and there was a trailer for $1300. that had a repaired I beam ? not to sure about that i would think the I beam is one of the main parts, I would hate to be towing and the boat ends up on the floor and im towing just a bit of trailer .
    1997 198SE Shabah Trailer Measurement Shabah 198SE Original Mariah Talk 0 08-07-2010 01:14 PM
    94 Shabah 212Z Total Weight with Trailer? Jbetschart Original Mariah Talk 5 07-27-2010 12:51 PM
    21' Shabah total length w/trailer...? jerrydeluca Trailering and Tow Vehicles 6 01-20-2009 01:46 AM
    1999 Mariah Shabah -- which trailer? kgoo Original Mariah Talk 3 09-23-2008 02:10 PM
    There are 342 users
