I finally got my new interior finished, well almost.
Old 03-10-2011, 04:33 PM   #31
Cory's Avatar
Cory is currently offline
My Engine: 5.7
Send Cory:
Default Re: I finally got my new interior finished, well almost.
Did you have to build a box behing the panel you put the subwoofer in? I'm thinking about putting in one 12"sub on passenger side. Wanted to know about soud quality from sub?
  • Old 03-10-2011, 04:37 PM   #32
    Cory's Avatar
    My Engine: 5.7
    Send Cory:
    By the way awesome job on system install, just gave me great ideas for my boat!!!
    Old 03-10-2011, 04:48 PM   #33
    Cory's Avatar
    My Engine: 5.7
    Send Cory:
    Just had a thought , where did you mount your amp???
    Old 03-10-2011, 04:49 PM   #34
    Cory's Avatar
    My Engine: 5.7
    Send Cory:
    If you happened to have pictures of amp placement , would like to see them..
    Old 03-10-2011, 09:48 PM   #35
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Holy multi-post Batman.
    Bear in mind; you could use free air subs.
    NathanMcMahon - I think I missed your post before. Thanks a lot for the offer!
    Old 03-11-2011, 12:49 AM   #36
    Purple_Shabah's Avatar
    Purple_Shabah is currently offline
    My Model: Shabah 182
    My Engine: 4.3 Apha
    Gallery Images: 19
    Send Purple_Shabah:
    Wow!! Really nice, impressive!! Where did you get the carpet? thinking of carpeting mine.
    Time flies when you're having rum.
    Old 03-13-2011, 05:50 AM   #37
    Hyperryd's Avatar
    Hyperryd is currently offline
    My Model: Shabah 198
    My Engine: 5.7L Alpha
    Send Hyperryd:
    Yes I built sealed sub enclosures behind the factory kickboards. I find sealed enclosures work great on boats because in a sealed box the backpressure controls the cone movement keeping the sub from overexcursion that tends to tear up ported and free air subs. This isn't a problem in cars, because you don't normally have it turned up as loud or as long as an open cabin boat. It is tight behind those boards, but you can build a pretty tall box to help get the airspace needed. If I get a chance I will post some pics of the amp's. They are mounted in the rear storage compartments on the side walls. Luckily Mariahs are so deep they never get wet back there and they are easy to wire to the batteries and onboard charger.
    Purple, I got the marine carpet at an upholstery supply house. Laying the carpet is pretty easy, getting the enitre interior out first isn't.
    Thank you Hyperryd for this useful post!
    Cory (03-13-2011)
    Old 03-13-2011, 07:10 AM   #38
    Cory's Avatar
    My Engine: 5.7
    Send Cory:
    Any pictures would be appreciated!!!!!
    Old 03-13-2011, 11:33 PM   #39
    Hyperryd's Avatar
    Send Hyperryd:
    Here are a couple of pics of the amps. I used a couple of used amplifiers that I had, so one fit nicely in one of the rear pockets and one had to mount on the outside. I will probably replace the bass amp with on that is a little bit smaller to match the highs amp and give me a little bit more room in that compartment. The yellow box is the onboard 2-bank charger.
    Old 03-14-2011, 01:11 AM   #40
    spinks99 is currently offline
    My Model: Z202 Shabah
    My Engine: 5.0 LX Alpha One
    Send spinks99:
    Hyper,
    That is one of the most beautiful boats I have ever seen! These Mariahs blow any new boat manufacturer out of the water.
    I am installing a new stereo this year. My boat is covered up in the garage, but I was also thinking of installing a 10 or 12" sub under the drivers side like you did. Did you cut a hole there? What is behind it. Is that the front storage bin? Where are your amps located? What do you think of Bazooka tubes, or don't you?
    I would like to copy your set up. Thanks in advance for the info.
    Danny
    Finally a few pics... AirNavy Original Mariah Talk 15 10-16-2009 03:30 PM
    FINALLY! It's fixed. jeffryb Original Mariah Talk 1 10-10-2009 09:29 AM
    Finally did my official shake down run in 94z190talari Original Mariah Talk 5 07-14-2009 10:24 PM
    Bravo III skeg repair finally finished WetWilly Original Mariah Talk 35 05-10-2009 08:29 AM
    How to Tell Winter's Finally Here... ShabahZ280 Chit Chat/Off-Topic 2 01-29-2009 08:36 AM
    There are 507 users
