Ignition switchy came loose on my Z258 Shabah
Old 06-05-2010, 01:51 AM   #1
mickman1959's Avatar
mickman1959 is currently offline
My Model: 1999 Z258 Shabah 7.4L MPI Bravo III
Gallery Images: 8
Send mickman1959:
Default Ignition switchy came loose on my Z258 Shabah
How can I tighten my ignition switch. i have a 1999 Z258 Shabah cuddy. My ignition switch came loose and the whole switch turns when i try to start my boat. The only access is a small panel in the cuddy. i can barely see the tightening nut from there and there are all kinds of wiring and harnesses in the way along with bracing. I can't see any other way in from the dash. Can anyone help and give me an idea on how to tighten the nut?
  • Old 06-05-2010, 03:06 AM   #2
    dieselwiezil is currently offline
    My Model: 2000 Mariah 212 5.7V8 Mercruiser Alpha I 21p mirage plus 48-13702
    Send dieselwiezil:
    Default Re: Ignition switchy came loose on my Z258 Shabah
    90* needlenose and GREAT LUCK, Its a PITA
    2000 Mariah 212 Mercruiser 350
    2002 F150 Supercrew
    1996 F250 Diesel lots of power goodies.
    "Out of everything I have, I still prefer riding MARIAH"
    Old 06-05-2010, 01:26 PM   #3
    Hi mickman1959, dieselwiezil right, you may need to resort to unusual tools to get the job done.
    You could also fashion a custom tool for tightening the back nut on the switch - acquire a "long" open end wrench of the proper size, clamp it in a vise, heat up the wrench about 3 to 4 inches back from the wrench head and make a 90% bend, let cool and it should work to get around the wires, or you could make a wrench from steel bar stock and a Dremel to do the same thing.
    Good luck,
    Old 06-07-2010, 11:05 AM   #4
    Billyclub is currently offline
    My Model: 1999 Shabah 182 Mercruiser 3.0L
    Send Billyclub:
    I had the same problem with my shabah 182 last year. I placed a nut on the dashboard side of the switch and used it to tighten against the rear nut. Good luck and watch out for sharp fiberglass.
    Mariah keypad ignition? BobZ270 Original Mariah Talk 1 12-30-2009 09:52 PM
    Possible Ignition Problems?? Help! jeffryb Original Mariah Talk 3 09-18-2009 12:28 AM
    Loose Seat sweetness34 Original Mariah Talk 1 09-05-2009 08:24 AM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    There are 312 users
