1995 27.5' Mariah Shabah
Old 01-12-2010, 04:46 PM   #1
classicdetail is currently offline
Send classicdetail:
Default 1995 27.5' Mariah Shabah
Hello, I am a first timer and have a quick question. I have the chance to buy a 1995 27.5' Shabah which is a cabin boat and has the 454 Merc. The owner seems unsure of the model. Is there a Z275? The boat appears in immaculate condition with 125 hrs and has never had bottom paint as it has always been trailered. The only things needed are steering cable adjustment and he says the hydraulic trim is "hit and miss". Is this easy to remedy? The boat has a Zieman trailer. I was wondering if someone could tell me the estimated value of this boat, both with and without the trailer. Thanks!
  • Old 01-12-2010, 08:29 PM   #2
    Default Re: 1995 27.5' Mariah Shabah
    Yep, there was a 27.5' cuddy cabin boat made by Mariah in 1995, it was the called the "Davanti" model, not the "Shabah". There were two 27 foot models that year, the Z272 Barchetta (bowrider) and the Z275 Davanti (cuddy cabin). In 1996, they were both renamed to the "Shabah".
    The steering cable, and the hydraulic trim tabs can be replaced. We've got members here who have replaced them, and we have many links to OEM manufacturers and parts.
    A great place to check the value of the boat is NADAguides.com Official Site.
    Good luck and if you have any more questions, feel free to ask. We're all here to help!
    Old 01-12-2010, 09:45 PM   #3
    Send classicdetail:
    Chris, Thanks for the reply. It's been a great help. I'm going to follow the link you provided and see what the boat is worth. I have a feeling I may soon own a Mariah. Thanks again, Doug
    Old 01-13-2010, 02:30 PM   #4
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    If it just needs a new trim motor (probably does, if it's hit or miss), that's not too big a deal. Anywhere from $2-400 for the motor and it should be a breeze to install as long as it's easily accessible, which it probably is because its reservoir should be checked on a regular basis. $200ish if you can find the pump alone, $400ish if you have to buy the entire assembly.
    That would actually be worse case scenario too. If you're lucky one or both of the solenoids are just out and they're only like $35 each. The test to figure out what is wrong is pretty easy. If you get to a point you're ready to do that just let us know and we'll help out or google around and you'll find plenty info.
    I think you're looking at a $10-12K boat, and that's being modest given the hours that are on it. My opinion and not that of the MOC, blah, blah, blah...
    1995 Shabah Z212 Electrical Diagram Jeff W Original Mariah Talk 4 07-26-2017 02:11 AM
    1995 Z202 Shabah - Glad to be a part! rjobe Introductions 7 07-18-2010 02:13 PM
    New 1995 Z202 Shabah Graphics spinks99 Original Mariah Talk 3 09-29-2009 09:42 PM
    Buying 1995 Shabah 202 today! Javier Hernandez Introductions 3 07-14-2009 05:42 PM
    1995 Mariah - 192 VernB63 Mariah Boats For Sale & Wanted 1 02-20-2008 01:48 PM
    There are 256 users
