Fuel Sending Unit
Old 11-26-2009, 06:26 PM   #1
Weezer's Avatar
Weezer is currently offline
My Model: 1993 Barchetta 4.3LX Alpha One
Send Weezer:
Default Fuel Sending Unit
I have a 93 Barchetta (not a Z). I need to replace the fuel sending unit. I see 3 wires. The pink is for the sending unit. The black is ground. What is the green wire for? Does any body have an idea?
  • Old 12-02-2009, 10:51 PM   #2
    64*thunderbolt's Avatar
    64*thunderbolt is currently offline
    Status: SHABAH Z210
    My Model: SHABAH Z210
    My Engine: 5.7 EFI ALPHA1
    Send 64*thunderbolt:
    Default Re: Fuel Sending Unit
    hey weezer, i belive the green wire is a ground wire that grounds your fuel filler door,(cap ) to the fuel tank . to pevent staic electricty from createing a spark as you add gas to your tank
    Old 12-02-2009, 11:15 PM   #3
    Weezer's Avatar
    Send Weezer:
    Thanks for the reply. But, I thought the black wire was the ground (according to the schematic). Are there 2 grounds?
    Old 12-03-2009, 06:27 AM   #4
    Hi Weezer, I believe 64*thunderbolt is absolutely correct, and that would mean the green wire is a secondary ground from the gas cap back to the tank. It's necessary because the boats hull being fiberglass does not act as a ground and since the gas cap is connected to the main tank by a rubber hose the green wire is necessary for the reason stated by 64*thunderbolt.
    Old 07-05-2022, 04:44 PM   #5
    MR2NR's Avatar
    MR2NR is currently offline
    My Model: Barchetta Z
    My Engine: Reman Vortech 4.3 A 1
    Gallery Images: 7
    Send MR2NR:
    Best way to preserve the carpet and access the sender?
    Old 07-05-2022, 10:03 PM   #6
    MR2NR's Avatar
    Gallery Images: 7
    Send MR2NR:
    Ok I got it. Nice little hinge . I cleaned the terminals and the needle goes directly to E when I hit the switch so Im looking for a new sender.
    Old 07-06-2022, 03:42 AM   #7
    Amazon has them by the dozens. Get one with a 33 - 240 ohm range.
    fuel sending unit kbrandt Original Mariah Talk 1 07-06-2009 06:57 PM
    2000 185 shabah fuel sending unit muskokaguy Original Mariah Talk 5 10-28-2008 12:11 AM
    Which GPS unit blockp Original Mariah Talk 4 10-21-2008 03:40 PM
    i/o lower unit gear oil bryce6horse Mercury MerCruiser 1 04-25-2008 03:53 PM
    Need to pull the sending unit MariahShabah3.0 Original Mariah Talk 5 02-21-2008 03:01 AM
    There are 299 users
