Fuel tank z210
Old 11-14-2009, 12:58 AM   #1
64*thunderbolt's Avatar
64*thunderbolt is currently offline
Status: SHABAH Z210
My Model: SHABAH Z210
My Engine: 5.7 EFI ALPHA1
Send 64*thunderbolt:
Default Fuel tank z210
I keep smelling gas fumes in the floor storage compartment when i lifted the hatch,so i raised the rear seats, removed the two engine side covers, removed two screws that holds the fuel tank cover that is over the gauge sending unit and hose connections, i found the fuel leak at the sending unit, leaky gasket. The biggest surprize that i found was that my 96 shabah z210 has a poly fuel, tank not alum . Also acording to the lable on the tank, the cap. Is 35 gallons not 40. Surprize, surprize
  • Old 11-16-2009, 03:32 PM   #2
    Tom
    Tom is currently offline
    My Model: 1994 Talari 18 4.3 LX
    Send Tom:
    Default Re: Fuel tank z210
    Check the filler neck on the tank. We couldn't find our leak for awhile and found there was a small crack where the filler neck joins the tank. We got an exact replacement from Kracor in Milwaukee-there the ones who built the originals. I ordered it through the Lewis Co. 954-523-4371 as they were able to sell it to me less than directly from the company and I had it in about 10 days. Hopefully your tank is okay and doesn't need to be replaced.
    Old 11-21-2009, 11:04 PM   #3
    Status: SHABAH Z210
    THANKS TOM, YOUR RIGHT ! I HOPE I`LL NEVER HAVE TO REPLACE THE FUEL TANK, LOOKS LIKE A MAJOR JOB. LIKE THE BOAT WAS BUILT AROUND IT, ANYWAY IT LOOKS LIKE IT `S THE GAUGE SENDING UNIT, THERES DRIED FUEL LAYING ON TOP AROUND THE SENDING UNIT.I HAD TO CLEAN IT OFF OF THE LABLE TO SEE THE TANK CAPACITY, THANKS FOR THE TANK MANUFACTURES NAME AND NUMBER. I`LL SAVE IT JUST IN CASE. JACKIE
    What size is my fuel tank? Hyperryd Original Mariah Talk 4 10-10-2011 02:02 PM
    Leaky fuel tank? grommett Original Mariah Talk 12 07-27-2009 04:22 PM
    Fuel Tank Leak Roger Butterfield Mercury MerCruiser 10 05-27-2009 05:15 PM
    fuel tank capacity jchemotti Mercury MerCruiser 9 07-04-2008 05:41 AM
    Where's my fuel tank? hey C Original Mariah Talk 9 01-23-2008 12:20 AM
    There are 260 users
