Need Some Docking Advice
Old 10-02-2009, 02:21 PM   #1
Z280Bob's Avatar
Z280Bob is currently offline
My Model: 1999 Z280 7.4L Bravo III
Send Z280Bob:
Default Need Some Docking Advice
My biggest problem and a new boater is still backing the Z280 into my slip. What is constantly happening is the bow is swinging to the right as I attempt to slowly glide into the slip and tie to the posts on the port side of the boat. This happens even on a calm day like this past Wednesday and the harbor is in a protected inlet with I believe no current. When I reach my slip after gliding a bit, I bump the gear into forward and and bring the boat 90 degrees to the starboard and then bump it in reverse a few times trying to approach the dock at a shallow angle. Still, no matter what I do, the bow swings away from the dock towards the opposite side of the slip. What am I doing wrong or need to do to solve this problem?
  • Old 10-02-2009, 06:34 PM   #2
    lomitabob's Avatar
    lomitabob is currently offline
    My Model: 2001 Z250 Shabah 7.4LMPI Bravo I
    Gallery Images: 12
    Send lomitabob:
    Default Re: Need Some Docking Advice
    This is probably due to "prop walk". Single screw boats walk to one side more than the other when in reverse. Here is a link that explains it better. http://en.wikipedia.org/wiki/Prop_walk The only answer is to practice until you can anticipate the amount of walk your boat has... I even changed slips once to make it easier to dock...
    Old 10-02-2009, 06:57 PM   #3
    Z280Bob's Avatar
    Send Z280Bob:
    Your slip change or just change sides of the slip so I am tieing off on the starboard side rather than the port side might help. My assigned slip has me on that side but unfortunately they parked a very wide and expendsive boat on the port side of the slip so I don't have much room which is why I have parked where I am currently.
    Old 10-02-2009, 07:28 PM   #4
    Tom
    Tom is currently offline
    My Model: 1994 Talari 18 4.3 LX
    Send Tom:
    The prop walk is even more significant in sailboats. I struggled with the same issues on my 36 footer. What I did is take it on the lake where there were buoys or moorings and practiced backing into them-no damage!! The wind is also an issue, but again less with your boat than a sailboat, but it will catch the bow and move it around. To be honest I never did get very good at it and decided going in bow first was alot easier!! We only have an 18 footer, so I haven't had a problem with it, but we're never going into slips either.
    Old 10-02-2009, 08:12 PM   #5
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Sounds like you're trying to do most (or all) of the turn while in forward. Then you put it in reverse a couple times to back in. My suggestion is to try only 45 degrees of the turn in forward, then back it in. The momentum of the bow swinging around should continue while you're going in reverse into the slip. Z280Bob has a Bravo III, so I don't think prop walk would be much of an issue.
    I know, sounds easier than it is. I'd like to see ANYONE back into a slip "perfectly" without twins or a bow thruster!!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 10-04-2009, 03:44 AM   #6
    95Z212's Avatar
    95Z212 is currently offline
    My Engine: 5.0LX Alpha 1
    Send 95Z212:
    Hold my beer and watch this sh!t!
    1995 Shabah Z212 V8
    2012 CRF 450R
    My location
    Old 10-06-2009, 07:01 PM   #7
    Z280Bob's Avatar
    Send Z280Bob:
    IndyKoch,
    Tried your 45 degree approach suggestion and I was able to get in better with a little help from a boat captain that grabbed my bow line as I was coming in. And I did see someone with twin dtives and thrusters on a 35'+ Carver back in perfectly. For a few $hundred G's he should be able to park easier than I can with my humble craft!
    Old 10-09-2009, 10:36 AM   #8
    Snowaterdude's Avatar
    Snowaterdude is currently offline
    My Model: 1993 Mariah Talari MX
    My Engine: 5.0 L Alpha 1
    Send Snowaterdude:
    Here is one common mistake....when you dock , often you have to change from forward gear to reverse. At the same time you have to turn your steering wheel. When getting closer to the dock, if you have to put your boat into reverse and turn the wheel, first, you shoud put it in neutral then do your wheel adjustment.
    In a nut shell, everytime you change from reverse to forward or vice versa, put the boat in neutral and do your steering adjustment, then put it in forward or reverse. A lot of people don't know that. They will switch gears and try to steer while the boat is still in motion sending the vessel all over......Always make your steering adjustment while the boat is in neutral.
    Thank you Snowaterdude for this useful post!
    mikeyt (06-01-2010)
    Old 10-09-2009, 02:25 PM   #9
    indykoch's Avatar
    Send indykoch:
    Great point Snowaterdude! I've seen many people make that mistake.
    While we're on the subject, here's another one - try to remember the source of propulsion AND steering are located at the very rear of the boat. I can't help but laugh when I see someone parallel to a dock just pull away while turning the wheel (almost like they're in a car pulling away from the curb), then the stern smacks into the dock, and skipper's looking around to see if anyone saw him/her - then they have a puzzled look of... "how did that happen?"
    Ryan
    350 Mag MPI
    Old 06-01-2010, 04:39 PM   #10
    jdecoudres's Avatar
    jdecoudres is currently offline
    My Year: 2008
    My Model: sx20
    My Engine: 5.0 alpha 1
    Send jdecoudres:
    Any advice on how to drive in and out of boat slip with out hitting the sides. I just got a slip this year and caint seem to drive in and out straight. I sit around and watch other ppl and they make i look so easy.
    LED Docking lights for your Mariah mikeyt General Maintenance 16 06-18-2010 11:31 PM
    Replacement Docking Lights plenty Original Mariah Talk 1 09-25-2009 10:37 AM
    Docking light adjustment? ckgreenman General Maintenance 10 07-10-2009 10:09 PM
    Wanted: docking light bulb lcoen777 Mariah Parts For Sale & Wanted 14 07-09-2009 06:41 AM
    Boat docking Mark Original Mariah Talk 14 04-02-2008 02:26 AM
    There are 360 users
