Boat docking
Old 10-04-2007, 11:34 PM   #1
Mark's Avatar
Mark is currently offline
My Model: 182 shabah
My Engine: 4.3L
Send Mark:
Default Boat docking
I really hate to do it but next summer I have to dock my boat. The question is, should I paint my bottom first? If so, what kind of paint should I purchase, and how should it be applied? I just can't wait in boat ramp lines anymore, especially when I have a weak wife who can't help much. Thanks Mark
  • Old 10-05-2007, 12:07 AM   #2
    Mark, check out Interlux. They make all sorts of paints, and are available in many stores like West Marine, Boaters World, etc. You can do it yourself, or pay someone to do it.
    But yes, you should definitely do it before you put the boat in the water.
    Old 10-05-2007, 02:56 AM   #3
    I wuz more concerned about which 'bottom' he wanted to paint....his or his boat's.
    Old 10-05-2007, 03:57 AM   #4
    Oh m'god mikey.... hope you weren't getting a visual while thinking about that one..........
    Gotta admit though, I was almost there too..but hey, I'm losing my mind so I can get away with it!!!!!
    Seriously though, ShabahZ250 is right, paint the bottom.
    One more thing, if your running a Mercruiser outdrive, you might want to follow their advice (got this from their web site): http://www.mercurymarine.com/service...osion.php#1174
    Can I use anti-fouling paint?
    Anti-fouling paint may be applied to boat hull and boat transom, but you must observe the following precautions:
    * IMPORTANT: DO NOT paint anodes or MerCathode system reference electrode and anode, as this will render them ineffective as galvanic corrosion inhibitors.
    * IMPORTANT: If anti-fouling protection is required for boat hull or boat transom, copper or tin based paints can be used if not prohibited by law. When using copper or tin based anti-fouling paints, you should avoid any electrical interconnection between the MerCruiser product, anodic blocks, or MerCathode system and the paint. Allow a minimum of 1-1/2 in.
    (40 mm) UNPAINTED area on the transom of the boat around these items.
    * Sterndrive unit and transom assembly should be painted with a good quality marine paint or an anti-fouling paint that DOES NOT contain copper, tin, or any other material that could conduct electrical current. Do not paint drain holes, anodes, MerCathode system, and items specified by the boat manufacturer.
    Good luck,
    Old 10-05-2007, 03:18 PM   #5
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Mark,
    Great advice here. I agree, get the bottom paint. I don't know what your waterway is like, but mine's terribly full of marine growth (a.k.a. SLIME). I slip mine all year. It had a new coat of bottom paint and still had some growth (see pic). I've heard of boats losing 10-15 MPH, blistering of the gel coat, etc. from the slime. It may not look great, but it's well worth it. I'm leasing a lift next year so I don't have to deal with any of it anymore. It's a pain to clean it off!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 10-05-2007, 07:19 PM   #6
    whoa, you can lease lifts? nice!!
    now what about the smart tabs, do they recommend painting those? i never thought about that!
    Old 10-05-2007, 09:18 PM   #7
    Hi ShabahZ250,
    According to Boat Leveler Co., the brand Mariah used most, you paint just the metal tabs.
    I quote:
    "Painting of Tabs
    In order to keep growth from Cylinders and tabs, we recommend you see your local marine paint supplier for proper primer and anti-fouling paint. Caution: Do Not Paint Cylinder Rams
    And this is what Bennet had to say:
    "How do I paint my trim tabs?
    The secret to getting anti-fouling paint to adhere to your trim tabs is proper priming, and the best people to tell you what to do are the experts at the company that makes your anti-fouling paint. We strongly suggest that you contact the paint manufacturer and tell them you are painting "304 stainless steel" trim tabs, then follow their recommendations to the letter! Remember don't paint under the zincs.
    I would assume it would be the same for Smart Tab brand trim tabs too. I believe the normal Anti-fouling paint can affect the plastic Rams but I remember hearing there is a anti-fouling paint safe for the Rams but I don't know the brand or name.
    Old 10-06-2007, 05:27 PM   #8
    Mark's Avatar
    My Engine: 4.3L
    Send Mark:
    This is for Mikeyt . Should I stay away from my port hole when I paint ? Did I say that. Thanks for all the help guys you to mikeyt.
    Old 10-07-2007, 06:13 PM   #9
    You might want to stay away from your bilge hole though....
    Best of luck with the bottom painting. Let us know what product you choose & how it works out.
    Old 10-08-2007, 05:31 PM   #10
    indykoch's Avatar
    Send indykoch:
    Yeah, my marina leases slips with and without lifts. Supposedly, they adjust the bunks to fit your specific boat, but I'll be the judge of that.
    I don't remember where I saw it, but I believe Smart Tabs aren't supposed to be painted. They're stainless steel and the actuators have a rubber sleeve. I'll see how they look when I pull it out in a couple weeks. I'm hoping it's nothing the power washer I just got can't take care of!!
    Ryan
    350 Mag MPI
    LED Docking lights for your Mariah mikeyt General Maintenance 16 06-18-2010 11:31 PM
    There are 220 users
