Blower Not Working!!??
Old 07-31-2009, 12:57 AM   #11
depman160's Avatar
depman160 is currently offline
My Model: 2000Z
My Engine: 5.0L Merc Alpha 1
Send depman160:
Default Re: Blower Not Working!!??
my blower quit running couple weeks ago and just had a new one installed for $105 total, including parts and labor.
Sadly I am not good with electrical stuff or I'm sure it would have been cheaper than the $65 for labor I got charged!
Oh well, as they say, a hole in the water into which you throw money!
If only it could be summer all year long!
  • Old 07-31-2009, 08:08 AM   #12
    mashymariah's Avatar
    mashymariah is currently offline
    My Model: 2005 Mariah SX18
    Send mashymariah:
    Not sure if it's the same, but my blowers weren't working at first and the safety fuse kept blowing. I found in my case the fan was not working so with a bit of lubrication and manually rotating fan it worked ok since. Just make sure you have the switch off first! You may have tried this already but worth a try before you replace the blowers.
    Old 07-31-2009, 02:34 PM   #13
    Send 300sflyer:
    Originally Posted by ShabahZ250 View Post
    I can't believe these stories I've been seeing recently about not using bilge blowers!
    Seriously, if the blower isn't working, why not replace it? It's probably one of the cheapest things to replace on your boat. It's the Attwood Turbo series, and I picked one up for $20 brand new... I think it's also time to find a new mechanic. I wouldn't let one around my engine if he wasn't willing to replace a $20 part.
    Gas vapor collects in the bilge because it's heavier then air. Opening the engine hatch will bring a small amount of air in on top of the engine, but it's not enough to remove the vapors that sit in the bilge.
    Completely agree! Get your blower fixed! In a sense, you are playing Russian roulette with the lives of your passengers...
    Trim Tab not working. john elbro General Maintenance 4 07-28-2009 01:39 AM
    Exhaust Blower Inop twospeed46 General Maintenance 1 04-30-2009 07:46 PM
    rev counter not working craig Original Mariah Talk 3 05-13-2008 12:31 PM
    99' Z280 Blower Won't Shut Off Roger Butterfield Original Mariah Talk 3 03-31-2008 06:04 PM
    1999 Z280 Blower Switch Roger Butterfield Original Mariah Talk 4 03-26-2008 05:37 PM
    There are 285 users
