shabah question - blower
Old 08-24-2009, 03:34 AM   #11
Cliff_Haskins is currently offline
Send Cliff_Haskins:
Default Re: shabah question
Most all boats in general use a type of "pan" or box to mount their vents in. These will allow water to drain out without entry into the blower hose. Also, one could raise the level of blower hose 1/2" above the box, that way water has a harder time going into the hose. As for vents, one side will have a "dirty" exhaust air out (pressurized air with possible fuel fumes) and the other will be fresh air in(suction). Later NMMA standards required that the inlet air side have blower hose that reaches into the lower 1/3 of the bilge, but I believe these standards were not in place before Mariah shut down, so you may have a "box" with only holes in it, no hose.
    Blower Not Working!!?? toddneedham Original Mariah Talk 12 07-31-2009 02:34 PM
    Z252 Shabah Question Harley Introductions 0 06-10-2009 06:16 PM
    Exhaust Blower Inop twospeed46 General Maintenance 1 04-30-2009 07:46 PM
    1999 182 Shabah Question jerryann Original Mariah Talk 3 03-01-2009 03:06 PM
    99' Z280 Blower Won't Shut Off Roger Butterfield Original Mariah Talk 3 03-31-2008 06:04 PM
    There are 360 users
