running with a water hose/ear muffs
Old 06-03-2011, 07:16 AM   #11
baker721's Avatar
baker721 is currently offline
My Model: z210 Shabah
My Engine: 350 Bravo III
Send baker721:
Default Re: running with a water hose/ear muffs
Does anyone have pictures of this hooked up..... I don't see where I can hook a water hose or earmuffs to my bravo III
  • Old 06-04-2011, 03:25 PM   #12
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    You can kind of see where mine are in this video:
    YouTube - ‪Winterizing‬‏
    Old 06-04-2011, 05:39 PM   #13
    baker721's Avatar
    Send baker721:
    Where do I get them at
    Old 06-04-2011, 06:04 PM   #14
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Muffs? At a store that sells boating supplies? West Marine certainly has them, if you've one of those nearby. I wouldn't be at all surprised to find that either Wal*Mart or KMart has them.
    Jim
    “The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
    Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
    Old 06-07-2011, 12:11 PM   #15
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Before you go and buy muffs, you need to look at your waterpump. I also have the Bravo III and my water intake is a small port on the bottom of the hull and not on my outdrive. Apparently with the Bravo III, you can go either way. The way to tell is to locate your water pump on the engine(usually on the starboard side bottom front) and there are 2 hoses coming off the back. One should go to your engine(output) and the other will be your input and either go to your outdrive or go around your engine to a valve that is mounted on the engine room floor. If it goes to a valve on the engine room floor, don't put muffs on the outdrive because it won't work.(Believe me, I tried it when I first got my boat!) You will need to get a water flusher that looks like a toilet plunger. They are made for inboard engines, or install a t-valve with a garden hose fitting into your water intake line.
    Hope this helps!
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Thank you csterner for this useful post!
    baker721 (06-10-2011)
    Old 06-07-2011, 01:57 PM   #16
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    YouTube - &#x202a;Winterizing&#x202c;&rlm;
    That sounds great! You just need a longer video now and goose the engine a little!!!
    2001 Shabah Z275 ST
    Dredd (06-09-2011)
    Old 06-09-2011, 09:33 PM   #17
    Dredd's Avatar
    Send Dredd:
    The plunger looking ones are often referred to as, fake-a-lake.
    Thanks for the compliment, csterner. I often still smirk when I fire it up.
    Old 06-13-2011, 02:44 PM   #18
    Rick Smart is currently offline
    My Model: z272
    My Engine: 7.4 Bravo III
    Send Rick Smart:
    If you are running a stern drive using a flusher, you should be able to place your hands on the top of the exhaust risers without any discomfort. As mentions previously a sterndrive does not incorporate a weep hole to indicate water flow. Be careful when using a motor flusher they will slide off of the outdrive due to the water pressure from the hose and slick painted surface. I use a duel intake motor flusher since I have a 7.4 and I use bungee cords to prevent the flusher from moving while I run the engine.
    Cable running to leg Colin Logie Original Mariah Talk 2 05-06-2009 10:41 AM
    Running Amp Power??? stereoman405 Original Mariah Talk 5 05-02-2009 12:44 PM
    What prop are you running? KSP181 Prop Talk 12 11-20-2008 10:55 PM
    Just got a 2006 SX19, now I need to get it running ;-) 06_19SX Introductions 2 06-12-2008 04:14 AM
    how much water do you take on? bpfirrman General Maintenance 7 04-29-2008 09:35 PM
    There are 313 users
