With four people, I can't get it up.
Old 06-23-2009, 08:40 PM   #41
blockp's Avatar
blockp is currently offline
My Model: 99 Jubilee 214
Gallery Images: 8
Send blockp:
Default Re: With four people, I can't get it up.
You could find out by letting it slip for a while (without over revving), then pop your sun pad and check for burned rubber smell.
If still no smell, I've got to think the prop ventilating, but still odd that both the 21 and this 19p do the same thing.
  • Old 06-23-2009, 09:42 PM   #42
    grommett's Avatar
    grommett is currently offline
    My Model: Z202 Shabah
    My Engine: 350 Magnum 5.7L Alpha
    Gallery Images: 10
    Send grommett:
    I was looking for something else and found this: http://www.mercstuff.com/spunprop.htm
    Ventilation is a possibility if exhaust gas is getting outside the prop hub due to the wrong thrust washer or worn outside edge of outdrive. I tried a 21p stainless laser-II on my boat which had ventilation holes and I got a similar problem.
    Old 06-24-2009, 01:47 AM   #43
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Originally Posted by abillmann View Post
    Here's the best way I can describe it:
    If you set your drive position to half-way between fully down and fully up (not the trailer position, but halfway between the normal full "up" and "down" positions) and hit the throttle, you'll get the same result -- lots of RPMs, lots of wake backwash, rising bow, and maybe a 50/50 chance of getting on plane.
    This is likely the reason why it was likely some debris. Weeds or an obtrucion (like Indy says) in the drive travel on that trip may have been the issue. If it does happen again, simply shut off the motor, trailer trim the drive and put it all the way down again. Start er up and see if you have any more problem.
    My Mariah
    hello people mark keough Introductions 4 07-14-2008 02:51 PM
    Total Threads: 13,324
    There are 402 users
