Ideas/Help on multiple battery banks
Old 06-23-2009, 03:04 AM   #1
bdbyrnes's Avatar
bdbyrnes is currently offline
My Model: Talari z240
My Engine: 7.4L V8 - Bravo III
Gallery Images: 41
Send bdbyrnes:
Default Ideas/Help on multiple battery banks
Folks-
I have two banks of batteries; Blue Top Optima's for starting and Yellow Top Optima's (deep cycle).
I want to use the first bank when the engine is in the 'On' position and the second bank only in 'Accessory.' (Multiple Amps, Stereo etc.)
I originally had everything working well and when adding a couple more batteries I have clearly messed up what is connected where. Anyone have any quick tips or recommendations?
Thanks in advance,
Brent
1995 Talari Z240
7.4L Merc, Bravo III Outdrive
Corsa Performance Captains Call Exhaust
Samson Sports Tower
  • Old 06-24-2009, 02:51 AM   #2
    AirNavy's Avatar
    AirNavy is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Alpha One
    Send AirNavy:
    Default Re: Ideas/Help on multiple battery banks
    The easiest/safest way to do it will be to run all of the power wires for the amps and what-not through a high amperage relay (usually called a solenoid in the amp range you'll be looking for). Then use an acc lead to energize the solenoid coil. The highest amperage rating one I have personally used was a 100 amp that I used to control power for 4 12V compressors in an air suspension in my old truck. Be sure you get one with a 100 % duty cycle. Starter solenoids have a high enough amp rating, but only have about a 20% duty cycle. The place I found the ones I used was Wrangler power products.
    Mickey
    AEC (AW) U.S. Navy
    Dual Battery System twospeed46 General Maintenance 6 06-18-2018 02:46 PM
    Help with decal ideas stereoman405 Original Mariah Talk 7 04-17-2009 05:01 AM
    Stern drive refinishing ideas needed. bblauvelt Mercury MerCruiser 3 10-28-2008 10:10 PM
    Battery Monitoring ShabahZ280 Boating 101 1 09-10-2007 11:31 PM
    There are 351 users
