Wobbly Captain's Chairs '99 182 Shabah
Old 06-08-2009, 03:04 PM   #1
1999Mariah's Avatar
1999Mariah is currently offline
My Model: 1999 Shabah 182 Merc 3
Send 1999Mariah:
Default Wobbly Captain's Chairs '99 182 Shabah
They're both a little wobbley, any idea how to fix?
  • Old 06-08-2009, 07:48 PM   #2
    Rick of Austin's Avatar
    Rick of Austin is currently offline
    Gallery Images: 4
    Send Rick of Austin:
    Default Re: Wobbly Captain's Chairs '99 182 Shabah
    I have the same problem on my Diablo, took out all the screws (long stainless wood screws) that held the base down, filled the holes with good wood glue then installed the screws... it stayed tight and firm for 1 day!
    Wish I knew what was under there, the next step may be to take all the screws out again, jam wooden matches dipped in glue in the holes and reinstall but I dont think it will help. It seems as if the base itself under the floor is loose.
    I'll be wacthing this thread for sure!
    Best Of luck,
    Rick
    Old 06-08-2009, 08:15 PM   #3
    lcoen777 is currently offline
    My Model: 1995 Z202 shabah 5.0L
    Gallery Images: 9
    Send lcoen777:
    i would try some plastic anchors i use them for alot of things and they always seem to be real sturdy....
    Old 06-08-2009, 08:54 PM   #4
    Wink Re: Wobbly Captain's Chairs '99 182 Shabah
    Hi 1999Mariah,
    Where is the wobble coming from, the floor, pedestal base or right under the seat on top of the pedestal?
    Old 06-08-2009, 09:36 PM   #5
    1999Mariah's Avatar
    Send 1999Mariah:
    Yeah, I guess I should have clarified where it's coming from, it seem to be just under the seat at the top of the cylindrical piece, maybe a bearing area?
    Old 06-08-2009, 10:28 PM   #6
    Hi 1999Mariah,
    Ah yes, this isn't too difficult to fix, if you have Springfield pedestals, there is are plastic cups (swivel bushings) that the sliders sits on and they get worn out over the years like in the following pictures:
    Read this thread (click here), it talks about the bushing for the Springfields and if you're pedestals were made by Garelick Mfg Co, what to check for and how to repair it.
    The link I posted on this thread (post #4) is down for construction but if you have the Springfiels pedestals, all you need to do is measure the outer diameter of the pedestal and you should be able to order the right size Swivel Bushing from any of these Springfield dealers - click here. BTW, my new bushings came with an additional plastic washer to go between the pedestal and the bushing to prevent the top of the pedestal from cutting into the bushing making for a smoother rotation.
    Old 06-08-2009, 11:49 PM   #7
    1999Mariah's Avatar
    Send 1999Mariah:
    Thanks for the quick and thorough response! I'm pretty sure it's the bushings you mentioned, I do have the springfield brand pieces, and will be getting a hold of them shortly, thanks again WetWilly.
    Old 06-09-2009, 12:13 AM   #8
    My pleasure, oh, one more thing... read my thread on what happened to one of our chairs, click here.
    You might want to check your seat spiders while you have the chairs off cause you never know what's happening under your butt.
    Old 06-09-2009, 02:42 PM   #9
    Gallery Images: 4
    unfortunately the play in my drivers eat is between the carpeted ring thats about 14 inches in diameter and the floor of the boat. Anyone seen that problem yet?
    Rick
    Old 06-10-2009, 12:31 AM   #10
    Hi Rick, this may seem like a silly question, but are all the bolts securing the pedestal to the floor tight, the carpet compresses over time creating more space below the base.
    If they're tight, have someone sit and gentley rock in the chair and see if it's the floor flexing.
    Let us know,
    captain chairs too high audiomngr Original Mariah Talk 8 08-14-2010 02:19 PM
    Some helps with Captain's Call operation stereoman405 Original Mariah Talk 7 05-21-2009 03:28 PM
    There are 217 users
