Z308 Pump issue
Old 10-22-2020, 11:53 PM   #11
Gearhead is currently offline
My Engine: 7.4 Bravo 111
Send Gearhead:
Default Re: Silly Question Time?
Do you have the cruiser waste system manual? I don’t have anything in my manual for my Z28 and cannot find the tank vent filter so I can replace it. There are two vent hoses coming from the grey tank and one disappears along the gunwales toward the bathroom but cannot access it. The other hose is also a mystery where it goes before it connects to the vent on the side of my boat.
  • Old 10-23-2020, 01:19 AM   #12
    Again, the original poster hasn't been here since 2011 so you are likely out of luck.
    Old 10-24-2020, 02:24 PM   #13
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Z308 Pump issue
    On my Z280, one of the large diameter hoses is the inlet/comes from the toilet, the other large diameter hose is the outlet which has a standpipe inside the tank to draw near the bottom. It goes to the deck plate on the starboard aft side of the boat so you can pump out the tank. The small diameter hose is the vent which also goes directly to a vent mounted on the starboard aft side of the boat.
    My Z280 had no filter, I added an inline filter so the poor soul who was sitting on the aft bench seat did not have to smell the contents of the tank every time someone flushed.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 10-24-2020, 11:26 PM   #14
    Send Gearhead:
    I took a picture and cannot tell which of the small hoses is the vent hose. I see the pump in hose from the toilet and the pump out hose, both large diameter. Here is a picture, the skinny black one seems to go to the side of the gunwale so I assume it’s the the vent hose but not sure why I have 2.
    cid:258847B0-E437-42AE-AFC5-491530557748
    Old 10-25-2020, 02:39 PM   #15
    My Model: Z280
    I cannot see the picture but are the small diameter hoses on either side of the tank, port and starboard? If so, the are most likely both vents.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 10-25-2020, 03:50 PM   #16
    Send Gearhead:
    Is there an email or phone number I can send the picture to you with? I am now thinking both may be vent hoses and I might have to block one and hook up a filter to the remaining vent or install two filters, one for each.
    Bilge pump issue adornare Original Mariah Talk 12 03-29-2010 03:30 AM
    Camper top for 2001 Z308 clintonbush1 Original Mariah Talk 2 08-15-2008 05:32 PM
    Parts for Z308 searching topgunwolf Original Mariah Talk 13 05-29-2008 11:50 PM
    Z308 [email protected] Introductions 2 04-14-2008 11:57 PM
    Z308 Parts - Dimensions topgunwolf Original Mariah Talk 10 04-14-2008 11:20 PM
    There are 188 users
