Major problems with Talari 180!!
Old 08-27-2007, 04:00 PM   #11
indykoch's Avatar
indykoch is currently offline
Send indykoch:
Do you hear a moaning, grinding type of noise when turning at speed? If so, it could be your gimbal bearing. Mine robbed me of 10+ MPH and affected hole shot as well. I didn't know it at the time (new boat to me), but even at idle the engine made a clacking noise - now it's unbelievably quiet.
What's your top speed and RPM's? What size/pitch prop are you running?
Ryan
Previously - '99 Z212 Shabah
350 Mag MPI
  • Old 08-27-2007, 09:09 PM   #12
    Originally Posted by MariahShabah3.0 View Post
    Miket T......Did you lose any top speed? I'm almost sold to put the tabs on for next year. I also need a new prop. This one is pretty chewed. Our lake is so mismarked it's not funny. The major factor for me with a new prop will be hole shot to pull a skier. The boat is a little over 2000lbs with a 3.0 135 hp. I definitely bog with people in the back seats on the hole shot. I'm pretty sure I have a 3 blade 14 1/4- 21 on there now. Any sugestions?
    Nope, no loss of top end. It hit 48-49mph before and hits 49mph now (maybe 50 with a strong wind behind it ). A chewed prop can really cause headaches with acceleration and WOT though. You could try a 3 blade 19p or maybe a 4 blade 20p prop which would definitely give you a little more ooomph out of the hole, particularly if you dont do much high speed cruising & want it more for the watersports. The Smart tabs will make a considerable difference also. You have to keep your WOT rpms within the recommended range for your motor though.
    Old 08-27-2007, 11:51 PM   #13
    moondance100's Avatar
    moondance100 is currently offline
    My Model: 1995 Z240 Talari 502 Bravo III
    Send moondance100:
    Jason, you said you were having trouble..does that mean you could previously get the boat to plane ok? If the engine is running ok, and you're doing everything you used to do to get it to plane, I'd look at the insert in the hub being spun.
    Doug
    95 Z240 Talari, 502, Bravo 3
    Old 08-28-2007, 01:21 AM   #14
    MariahShabah3.0's Avatar
    MariahShabah3.0 is currently offline
    Gallery Images: 1
    Send MariahShabah3.0:
    I think I'm going to demo some props over the next month. I'm liking the 4 prop idea.
    MariahShabah3.0
    Monroe, NY
    1996 Mariah Shabah 180 SE
    Old 08-28-2007, 02:31 AM   #15
    Dont overlook what the other posters are saying here though. It could very well be a spun prop that is causing your problems. You should have the hub checked & while you're at it get the prop fixed up so at least you can use it as a spare.
    Old 08-28-2007, 02:55 AM   #16
    Gallery Images: 1
    I am absolutely going to check the hub out as well. I definitely want this one repaired so the hub will be essential as well. I figured that when I demo the four blade, I'll have the hub inspected.
    Frank
    MariahShabah3.0
    Monroe, NY
    Old 08-28-2007, 01:22 PM   #17
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    Originally Posted by mariahstreet View Post
    Hello,
    I'm hoping someone here will be able to help me. I own a 1995 Mariah Talari 180. I've been having problems bringing the boat to plane. From a stopped position, when I put the throttle down, the boat takes forever to plane. I have to get everybody in the boat to stand up and move to the front in order for it to get speed and plane. Any suggestions as to how I can make this problem go away??
    Jason
    Hmmm the last time I had problems getting onto plane, one of my spark plug wires was hanging off. I hit a small-ish wake and it was enough to pop one wire off the distributor cap. But this doesnt sound like your problem, or you would have mentioned about harsh running / rough running etc.
    Test out the boats fuel system maybe ... ?
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 08-28-2007, 01:33 PM   #18
    Straad's Avatar
    Straad is currently offline
    My Model: Barchetta 182
    My Engine: 4.3 Merc
    Gallery Images: 8
    Send Straad:
    i had the same problem last week getting on plane, but the engine was running real rough
    turned out to be a battery conection (i posted abotu it in another thread) that lead to the trim pump and fuel pump was corroded and nto getting good contact
    but like i said i could tell as soon as i started it that it was running horribly rough
    Straad
    1995 Barchetta 182, 4.3L
    Southern Mid-Michigan
    fiberglass cabinet problems arice Original Mariah Talk 0 05-05-2008 01:45 PM
    Radio problems giterdnn Original Mariah Talk 2 04-28-2008 05:29 PM
    z276mcc has some problems roger Introductions 1 11-01-2007 03:32 PM
    There are 305 users
