Retractable Cleats
Old 04-15-2009, 11:37 PM   #1
Threejakes's Avatar
Threejakes is currently offline
My Model: 182 Shabah
My Engine: 4.3L Alpha 1
Send Threejakes:
Smile Retractable Cleats
I installed these cleats on the Mariah. The kids were getting hung up on the exposed original ones. They would catch on their swimming trunks and tear the material, not to mention the injuries. The hardest part was cutting the hole that they fit in. These boats are well built to be sure! The picture of the finished product speaks for itself.
Thank you Threejakes for this useful post!
Bowtiestereoman (07-26-2020)
  • Old 04-16-2009, 08:24 AM   #2
    il_Mio's Avatar
    il_Mio is currently offline
    My Year: 2008
    My Model: SX18
    My Engine: 3.0L TKS - Alpha I
    Send il_Mio:
    Default Re: Retractable Cleats
    Nice job !
    Old 04-16-2009, 03:53 PM   #3
    dbarnie's Avatar
    dbarnie is currently offline
    Send dbarnie:
    Very Nice!! What brand and size are the new ones that you put on? Thinking about doing the same when the boat comes out of storage.
    Old 04-16-2009, 09:06 PM   #4
    Threejakes's Avatar
    Send Threejakes:
    Smile Re: Retractable Cleats
    They are the 6" size. I am not near the boat now, so I can't tell you how wide they are. I got this kind because they are flat. Some of the cleats I looked at were somewhat rounded and stuck up from the hull. I didn't like the way they looked.
    I bought them from Consumers Marine Electronics
    5398 NE Greenville Blvd.
    Greenville, NC 27834-8616
    1-800-332-2628
    They are item # 31995 6" stainless steel flush mount cleats
    They are $159.98 for two + tax
    I know that's a lot of money, but my Dad used to say, "Buy Cheap-Get Cheap."
    I think they are worth it, and I wanted to do this only once!
    Old 04-17-2009, 01:28 AM   #5
    Are those push button cleats? Those are pretty sweet! Great job!
    My Z250 has similar flush mounted cleats, but no button. It has a recessed spot where you can get your finger in to pull the actual cleat out. The only bad thing is, that recessed area collects water, and when you push the cleat back in so it sits flush, BAM, a face and mouthful of nasty water!
    Old 04-17-2009, 03:55 PM   #6
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    I have the same type cleats. If you look at the back side of the cleats there are plastic plugs that can be removed to let the water drain out. It of course it will drain into the boat but it isn't that much and will dry or end up in the bilge.
    Better than in the face!
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 04-17-2009, 06:05 PM   #7
    No kidding! Thanks for the info John!!
    Old 04-21-2009, 07:29 PM   #8
    dbarnie's Avatar
    Send dbarnie:
    So John, did you buy the pop ups from Attwood then?
    Wasn't sure if they were wide enough to replace the screw holes from the standard cleats.
    Old 07-26-2020, 03:01 PM   #9
    Bowtiestereoman's Avatar
    Bowtiestereoman is currently offline
    My Model: Z198SE Shabah
    My Engine: 350 Mag Bravo III
    Gallery Images: 1
    Send Bowtiestereoman:
    This is awesome, nice work! Been looking at the same retro on my Shabah.
    Want to replace the cleats on 192 Shabah dbarnie Original Mariah Talk 4 03-03-2009 05:30 PM
    There are 237 users
