1996 Z235 Talari cuddy latch
Old 03-11-2009, 04:40 PM   #1
rssniff is currently offline
Send rssniff:
Default 1996 Z235 Talari cuddy latch
Could someone email me a picture of the latch that is on the sliding cuddy door on a 1996 Z235 Talari? Mine is missing and I would like to try to find a replacement. Also, any suggestions on where to buy one?
  • Old 03-12-2009, 01:08 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: 1996 Z235 Talari cuddy latch
    I don't have a picture, and I couldn't find one in the gallery, but in the Mariah parts list, there are links to the manufacturers for the latches
    Have a look in this thread on where to buy:
    Original Mariah Parts & Vendors List
    My Mariah
    Old 03-12-2009, 02:41 PM   #3
    Send a private message to fellow member 'Chicagoweb' and see if he will take a pic and send it to you since he has the same boat.
    Old 03-12-2009, 03:31 PM   #4
    Send 300sflyer:
    Here is a pic of the latch on my 94 Z235. Im sure yours would be the same.
    Old 03-13-2009, 08:28 AM   #5
    Hi 300sflyer, Great picture!
    Could I ask you a favor for a few more pictures?
    If you could, I would like (1) a pic of the other side of the latch and (2) a pic from the inside looking out with the latch in the closed/locked position but with the door open so I can see the latching arm, I think it's a hooked piece but I want to confirm it. Lastly, (3) could I get a pic of the part mounted to the dash/deck that the the latch mates to?
    Old 03-13-2009, 04:28 PM   #6
    Send rssniff:
    Great board, Thank you all for your help so far. Greatly appreciated.
    Old 03-13-2009, 05:24 PM   #7
    Send 300sflyer:
    More pics.
    The first is from behind in the locked position. My hand is holding the spring loaded cylinder "pushed in" so it would resemble what it would look like looked. Not locked, it would simply be flush on the inside, and the pin would be turned 90 degrees.
    The second is the lock pin receptacle, on the door frame itself. If you look at the shape, you can see how rotating the pin holds the door closed.
    Hope that helps!
    Old 03-14-2009, 03:42 AM   #8
    ChicagoWeb is currently offline
    Send ChicagoWeb:
    Mike -
    Mine looks the same... I have the assembly but my keys never worked. So basically I have never used it.
    If someone finds a replacement assembly I would be interested in purchase one to!
    ___________________
    ChicagoWeb
    1996 - Talari z235
    23.5ft w/cuddy cabin
    Prestige Custom Trailer
    Lake Freeman, IN
    Lake Michigan, IL
    Old 03-14-2009, 03:43 AM   #9
    Send ChicagoWeb:
    Just a FYI those links are not accurate for the z235 latches...
    ___________________
    ChicagoWeb
    1996 - Talari z235
    Lake Freeman, IN
    Lake Michigan, IL
    Old 03-14-2009, 03:45 AM   #10
    Send ChicagoWeb:
    Do you have problems with the (2) sliders that hold the cuddy door sticking? I have been using a marine grade (wd40) type silicone spray to grease the door for the past couple of years but I am looking for a better solution.
    ___________________
    ChicagoWeb
    1996 - Talari z235
    Lake Freeman, IN
    Lake Michigan, IL
    1996 Z235 Talari rednecke7 Mariah Boats For Sale & Wanted 1 07-06-2009 02:25 AM
    1996 Z235 Talari Acadianbasic Mariah Boats For Sale & Wanted 0 08-19-2008 07:57 PM
    1996 Mariah Z235 Cuddy Cabin Diablo180 Mariah Boats For Sale & Wanted 9 07-15-2008 06:35 PM
    1996 Talari 235 Cuddy aaron999888 Introductions 24 09-13-2007 05:04 AM
    There are 294 users
