High Pitch Alarm
Old 09-11-2023, 12:36 AM   #1
billyfitz is currently offline
My Model: Jubilee
My Engine: 310 Mercruiser
Send billyfitz:
Default High Pitch Alarm
Today is the first day I've cranked the boat in over a year. Both batteries were dead so I replaced them, turned the ignition on and checked all the gadgets and lights. It cranked right up within 3-4 seconds and after running about 20 seconds or so this very high pitched alarm sounds off in a steady stream. I had already checked the oil, had the water hose hooked up to it, the engine compartment was wide open so I closed it but the high pitch sound continued. The sound is coming from the dashboard area and it happens every time I crank it. Don't find any solutions in the owners manual.
Any ideas?
The oil pressure gauge is dead center at 40 and the engine temp is just under the midpoint of 175.
  • Old 09-11-2023, 12:22 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: High Pitch Alarm
    Most likely outdrive gear oil level is low.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 09-11-2023, 12:39 PM   #3
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Like Steve said, if your oil pressure is good and temp not hot, then most likely low gear oil in the outdrive.
    SX19 won't start and high pitch warning(?) noise 06_19SX Sea Fox - Mariah Talk 13 08-26-2023 01:26 AM
    alarm from high temp sensor jsewall82 Original Mariah Talk 7 06-29-2013 01:59 AM
    What pitch should I use mrichzx14 Prop Talk 4 08-02-2011 02:37 AM
    High-pitched alarm sound & high temp at high RPM petemcrunnel Original Mariah Talk 7 06-15-2011 05:57 PM
    High pitch engine whine wplaine Mercury MerCruiser 3 07-17-2010 12:12 AM
    There are 253 users
