Help with talari
Old 08-31-2021, 12:16 AM   #1
Dialboater is currently offline
My Model: Talari 210
My Engine: 5.0 alpha 1
Send Dialboater:
Default Help with talari
I am new to the site forgive me if I posted in wrong place. I have a 1994 talari 210 that I bought a couple weeks ago. When I bought it, it cranked long and finally did start and run fine. Previous owner said it had been like that for awhile but always started. I have had it out 3 times and have had longer crank times when I first get to ramp and once it starts it runs fine. After sitting for 30-45 mins swimming it is hard to start just not as bad as first getting to ramp. Any help would be appreciated. Have been looking into new fuel pump but can’t find any part numbers or it.
  • Old 08-31-2021, 09:02 AM   #2
    Sparks&Stripes is currently offline
    My Model: Jubilee Z244
    My Engine: 350 Mag Alpha One
    Send Sparks&Stripes:
    Default Re: Help with talari
    Would help to know what motor you have... could be fuel pump is weak or it could be time to rebuild your carb and do a tune up, all common things.
    Dan
    Upstate NY
    98 Mariah Jubilee Z244 - 350 Mag MPI/Alpha1G2
    88 Seebold Eagle 21 Closed Bow - 175 Suzuki OB
    97 Celebrity 240 Cuddy - 7.4 Merc/Bravo1
    88 Larson Delta Conic 250 Aft Cabin - 5.7 Merc/Alpha1G1
    86 Thompson Open Bow - 3.0 Merc/AlphaG1
    Old 08-31-2021, 11:01 AM   #3
    Send Dialboater:
    Sorry it’s a 5.0 mercruiser with mechanical fuel pump and 2 barrel carb. Previous owner said he had just replaced fuel filter in spring. Once it starts it runs good.
    Old 08-31-2021, 11:10 AM   #4
    I agree with S&S. It sounds like it just needs a good tune-up and timing adjustment first. Next in line would be a carb rebuild.
    Diff between Talari 220 vs Talari Z220 ckstiles Introductions 2 04-29-2013 02:23 AM
    Difference between 240 Talari & 240 Z Talari ? wunn Original Mariah Talk 3 07-03-2009 03:03 PM
    There are 508 users
