Cabin lights refurbishment.
Old 06-23-2018, 07:47 AM   #1
John822179 is currently offline
My Model: Z225 Davanti
My Engine: 5L FL V8
Send John822179:
Default Cabin lights refurbishment.
My gorgeous Z225 Davanti had problems with the Reading lights in the Cuddy.
Truth be told, only one out of the 4 twin light clusters worked.
I removed one of them for inspection.
The bezel plate over the two central switches pops off with gentle pressure from a small screwdriver.
Then the four screws are removed and the whole assembly can be lifted out.
Connections to the main wiring loom is by Bullet connectors, so these were disconnected and later replaced because of corrosion.
Using a volt meter, the switches proved to be faulty.
To be honest, I had little confidence in finding any replacements, but decided to try and identify them.
The micro switches slide out of the panel assembly and amazingly, had the manufactures name and part number on them!
A quick search on Google identified a USA supplier, Digikey, as a stock holder who were happy to ship to Northern Ireland .
Part number: 528PB-ND
Description: Switch Pushbutton SPST 5A 14V. Push to Make, Push to Break.
Three days later, 6 switches arrived, I like to keep spares
Switches fitted, a bit of soldering and heat shrink and LED replacements and I have a Cuddy that I can read in
Hope this helps someone out there
GregT and Motoxxx43 like this.
John822179
Mariah Z225 5L V8
Keep the dry side up
  • Old 08-13-2022, 02:30 AM   #2
    Poneill45 is currently offline
    My Year: 2010
    My Model: R19.9
    My Engine: 3.0mpi mercruiser, alp
    Send Poneill45:
    Default Re: Cabin lights refurbishment.
    This is awesome! May i ask you, where is the power source for the lights? I do t seem to have any power to them. I’ve heard that the boat needs to be on shore power and also battery switch turned on. That didn’t work for me. I can’t find any of my switches providing power to them. And I’ve tried with the key on also. I’m lost.
    Sorry for the distraction from the main topic. Finding any info in these has been near impossible. Checked the wiring diagrams provided on this site. Keep reaching a dead end.
    Thanks.
    Wanted: WANTED 96' Cabin lights 1996 Mariah Z252 Mariah Parts For Sale & Wanted 1 02-12-2018 12:26 AM
    Mid cabin open bow thedoorman Introductions 14 02-28-2014 07:49 PM
    nav lights and gauge lights not working lumbercitybravest Original Mariah Talk 5 08-13-2013 05:11 PM
    bow lights? spot lights? need some help... with night time navigation nglauer Original Mariah Talk 13 07-09-2011 06:36 PM
    Cabin Lights not working Daxgirl Original Mariah Talk 1 04-28-2009 04:07 AM
    There are 314 users
