New to me
Old 05-07-2018, 04:04 AM   #1
shortedout96 is currently offline
Send shortedout96:
Default New to me
New to the Mariah Owners Club, New to having a boat (have always had jet skis prior) just bought a 1993 Z212 Shabah! Knew Mariah was the one I was going to end up with. Had been in a barn for 5yrs so will have to get the old fuel run through her, prolly rebuild car and do a tune up. Spent most of Saturday washing outside of it and scrubbing the inside! Came pretty clean which will serve us for now until I decide to have the inside reapholstered. Motor sounds weak but new filter has already clogged with bad fuel!
Anyways a few questions has anyone drilled frail holes in the cup holders for drainage? My trim gauge isn’t working, have not put a volt meter on it yet to check voltage but where is the position sensor at? Have one bad dock light bulb which I intend to replace both with LEDs but was curious if there is a trick to getting them out of the rubber boot?
Thank You!!!
Adam
    There are 191 users
