Steering under load
Old 05-02-2018, 01:01 PM   #1
salc1219 is currently offline
My Model: shabah 200
My Engine: 5.7l
Send salc1219:
Default Steering under load
Good day all, I bought a 1996 Shabah 200 mid season last year. Boat seems in good condition except for minor cosmetics. The last time I took it out last year I ran into an issues once I was up to decent speed the boat was extremely had to turn to the left, no problems turning to the right. At low speeds no issues with turning at all only under load and the longer I drove it the harder it seemed to be to turn to the right.
Any suggestion as to where to start would be appreciated.
Thank you salc1219 for this useful post!
Bill (05-07-2018)
  • Old 05-05-2018, 12:59 PM   #2
    breakdown Bry is currently offline
    Send breakdown Bry:
    Default Re: Steering under load
    Do you have a mercruiser maintenance manual? There is a few maintenance recommendations for the steering system
    If not , I could take a picture of the page and text it to you.
    sixonesix 5fourzero03fiveone
    Old 05-06-2018, 01:30 PM   #3
    My Engine: 5.7l
    Send salc1219:
    I do not the boat did not come with any manuals, I did download the boat manual from the site but did not go into a lot of detail .
    I would appreciate any help you could lend, number is 770-634-9254
    Sal
    Old 05-06-2018, 10:26 PM   #4
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Do you have the Alpha drive? If so, it will have a torque tab fin just above the prop. Make sure it is not loose or pointed to one side too much. It is used to offset the torque of the outdrive so that steers evenly. If you rev the engine a bit when out of gear (2000 rpm), can you still steer it evenly?
    Also, you made contradictory statements about the hard steering direction, once it is left and later it is right. Which direction is the harder steering?
    Old 05-07-2018, 11:41 AM   #5
    My Engine: 5.7l
    Send salc1219:
    Sorry about the contradictory statements, it is only to the left when sitting in drivers seat, and only underload, 1500 rpm it is fine in both directions.
    Thanks for the pics, I will check it out and see how it looks.
    Sal
    Old 05-07-2018, 02:01 PM   #6
    My Engine: 5.7l
    Send salc1219:
    First I want to thank you for all your help, I do not have the stren drive you sent pics of, I have attached 2 pics of the drive.
    Sal
    Power Struggle Under Load LunenburgRider Original Mariah Talk 5 06-27-2012 05:04 AM
    Can't get the daggone boat to load up correctly! GRRRR LluberesMM Trailering and Tow Vehicles 13 08-02-2009 03:09 PM
    How to Load a Bayliner into a Pickup 101. z275st Chit Chat/Off-Topic 5 01-12-2009 01:29 PM
    alpha 1 load ratings lawmanbsi Original Mariah Talk 1 08-31-2007 06:15 PM
    There are 366 users
