Another Trailer thread.
Old 08-21-2017, 05:25 PM   #1
bigwhite66 is currently offline
My Model: jubilee 204
My Engine: 4.3l alpha 1
Send bigwhite66:
Default Another Trailer thread.
Instead of Hijacking a thread, here's my latest experience with our Prestige trailer. Someone mentioned to check around the holes in the bottom near the axle, well this is what happens when you don't find it first. Had a mishap when I was forced off the inside of a turn at Norris Lake, maybe 10-15 mph, tire hit a driveway and launched the trailer a couple of feet in the air. Didn't know I was off the road until I felt the hit and saw it in the air. Bent the bunk support, bent the wheel, bent the main frame. While repairing, found the other side was cracked, so fixed it at the same time. Also, when we bought this boat, it already had plates welded up by the hitch. So add this to your pre-trip!
chuse927 likes this.
  • Old 08-22-2017, 03:33 PM   #2
    My Model: 180 Diablo
    My Engine: 3.0 Mercruiser
    Send TN_Diablo:
    Default Re: Another Trailer thread.
    Unfortunate mishap.
    I think I see the axle and torsion mounting bracket. It looks like the damage occurred directly behind the bracket on the bottom side and the cross brace behind the axle. If so it would best if you can also reinforcement across the bracket area but I guess it would have to go to the outside since the cross brace is in the way. Looks like you could run a plate behind the entire fender wheel where it wouldn't show.
    Old 08-22-2017, 07:08 PM   #3
    Send bigwhite66:
    I did, Just don't have pictures of it. Didn't think I'd ever use the pics for anything until I was reading that other post!
    Old 08-23-2017, 02:32 PM   #4
    baholtz is currently offline
    My Model: 202 Shabah
    My Engine: 305
    Send baholtz:
    Yikes, yes the square holes sure area mess. Fix looks good!
    Thank you baholtz for this useful post!
    bigwhite66 (08-24-2017)
    New to thread jarmani7 Introductions 1 10-17-2014 08:04 PM
    new thread crasher32234 Introductions 2 06-10-2009 10:16 PM
    There are 288 users
