98 Z260 Electrical problems
Old 07-16-2017, 04:25 PM   #1
LarTam is currently offline
My Model: Z260 MCC
My Engine: 7. 4 L MPI Bravo 3
Send LarTam:
Default 98 Z260 Electrical problems
I recently quit getting 110 ac from shore power through out the boat. First noticed when battery charger not getting ac. getting ac to the panel and out of the breaker. Can't find it anywhere else. Thinking it must be a breaker tripped somewhere but I can't find one. Wiring diagram not much help. Checked all gfi plugs i could find. Any Ideas?
  • Old 07-16-2017, 06:38 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 98 Z260 Electrical problems
    Have you performed any diagnostics yet? Do you have shore power coming in and out of the main breaker in the electrical panel in the main cabin?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-16-2017, 11:32 PM   #3
    My Model: Z260 MCC
    Send LarTam:
    yes i have. pulled the panel off and verified 110 is going thru, the display is reading 110 also. check all the gfi's i could find but not getting anywhere. Tahnks
    Old 07-17-2017, 08:10 AM   #4
    Shawn s is currently offline
    My Model: 209 Talari
    My Engine: 5.7L
    Send Shawn s:
    try removing and reinstalling the brakers had a similar issue before (not with a boat) were you would get the 110 but as soon as you put a load on the circuit you lost voltage ended up being corroded connections
    Thank you Shawn s for this useful post!
    LarTam (07-18-2017)
    Old 07-18-2017, 12:17 PM   #5
    My Model: Z260 MCC
    Send LarTam:
    Thanks that sounds viable. My next step is to try and find the inverter. The manual says the 110 passes thru it when on shore power. Thinking it may be stopping there. Anyone know where that would be located?
    Electrical problems Unknownmariah General Maintenance 6 06-17-2016 12:48 PM
    Electrical starting problems Wong Original Mariah Talk 6 08-25-2014 05:00 PM
    268 MCC Electrical Problems Mbaumy Original Mariah Talk 0 07-12-2011 03:09 AM
    *SIGH* My turn for electrical problems... stereoman405 Original Mariah Talk 7 05-13-2009 08:33 AM
    Electrical problems on my 94 talari Z Brian Original Mariah Talk 5 06-20-2008 10:35 PM
    There are 309 users
