97 Engine Question
Old 03-13-2017, 01:35 AM   #1
Mr_Bill is currently offline
My Model: Z210 Shabah
My Engine: 7.4 Bravo 1
Send Mr_Bill:
Default 97 Engine Question
Hello all,
I have a 97 Z210 Shabah SS/LE
I am trying to figure out the engine specs and if I have a magnum motor or one of the peanut port engines - and do it with out pulling the intake.
The engine serial number is 0K038027. If I go to the mercruiser site it comes up and says 454 Mag but the it also says 7.4L Bravo 1
Help! I am not understanding this!
  • Old 03-13-2017, 02:03 AM   #2
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Default Re: 97 Engine Question
    I am definitely no expert on this, but Bravo 1 is the out-drive model and does not apply to the engine. 7.4 liters is the same as 454 c.i. (7.4 liters x 61 c.i./liter = 452 c.i. actually). So I think they are telling you the same thing.
    As to whether you have oval port heads or not, can't help you there.
    Old 03-13-2017, 02:17 AM   #3
    Send Mr_Bill:
    Thanks for the reply! Yes, your correct there, 454 & 7.4L are there same thing, but what I am trying to figure out is if it is a Magnum engine or a regular 454.
    Magnum motors had forged cranks, rectangle port heads and roller lifters and the regular 454 (7.4L) had a cast crank, oval port heads and a hydraulic cam.
    Roughly also about 30hp difference in them also.
    Old 03-13-2017, 02:23 AM   #4
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    I wonder if you can see the difference in the lifters by looking down the push-rod hole?
    Now once again, no expert, but isn't the roller lifter restrained from rotating and the hydraulic one is not? If so, you could watch the pushrods and see if they are is spinning while the engine runs.
    Old 03-13-2017, 02:34 AM   #5
    Send Mr_Bill:
    Never thought of that, I had thought about running a scope through the carb into the intake, should be able to tell if they are square port or not.
    The engine serial should tell though, I am just confused reading it.
    Old 03-13-2017, 02:36 AM   #6
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    See my edited reply above for another way maybe.
    Old 03-13-2017, 02:36 AM   #7
    Send Mr_Bill:
    I think all the push rods can spin. Rollers normally have a lock bar that actually keeps the lifter itself from spinning but not the push rod.
    Old 03-13-2017, 02:41 AM   #8
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    But the lifter is what makes them spin. If the lifter isn't spinning, the pushrod wont move much. Normally a hydraulic lifter hole is offset so that it spins and wears evenly.
    Old 03-13-2017, 02:51 AM   #9
    Send Mr_Bill:
    Its possible that might work, but lol - what a mess it would make !
    Old 03-13-2017, 02:57 AM   #10
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Maybe. I know the 5.7 doesn't throw much oil around. I've had the cover off and no oil escapes. But I don't know about the 7.4.
    Engine swap question Lex81 Sea Fox - Mariah Talk 6 07-18-2014 09:35 AM
    Prop engine question Shabah 198 4.3 zrx Prop Talk 8 08-20-2012 12:55 AM
    96 Z190 4.3 engine replacement question L&K's Z 190 Shabah Mercury MerCruiser 11 08-17-2010 01:05 PM
    Newbie Engine Oil Question Electrosilver Sea Fox - Mariah Talk 2 01-11-2010 03:12 PM
    Z308 - Pitch and Engine question! topgunwolf Mercury MerCruiser 0 04-25-2008 10:42 PM
    Total Threads: 13,324
    There are 338 users
