Tight pass through
Old 08-24-2017, 10:03 PM   #21
GaryDoug's Avatar
GaryDoug is currently offline
My Model: Z202
My Engine: 5.7L Bravo III
Send GaryDoug:
Default Re: Tight pass through
Originally Posted by ROY850 View Post
Those were my first thoughts when doing mine Firestone but my frame wasn't in line with the existing holes so I couldn't drill into the frame I would do that though if it's doable on your end. Trust me it killed me to drill new holes, but it was either have a window that wouldn't shut or drill the new holes and correct the issue and deal with it lol. The great thing is my weatherstrip covers the holes but I plan to fill them at a later time. Right now I'm having to much fun with it.
I finally got the time and nerve to address this issue. It was way easier than I thought to move the windshield sections about 1/2" farther apart at the front. Took about 45 minutes. Pull out the rubber hose from the channels, remove the screws, move the fronts of the windshield parts farther apart (using the center section as a guide), drill new holes, and re-install the screws and hoses. The holes in the aft sections stayed the same. Just the holes for the front section were shifted slightly. Now the center window closes easily again. Also, there are no old mounting holes visible.
Tip: Measure the overlap of the center window (example: 1/2") and use that figure to determine how far apart to moves each half (example: 1/4" on each side). I left the rearmost two screws attached on each side to make sure the halves didn't move more than I wanted (and go overboard).
Thank you GaryDoug for this useful post!
Firestone (08-24-2017)
  • Old 08-24-2017, 10:09 PM   #22
    My Model: Z202
    Send Firestone:
    Nice! This is a winter project that I really want to get done. Any pictures?
    John
    Old 08-24-2017, 10:33 PM   #23
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    I didn't take any photos because it went so easily and quickly. There simply wasn't anything interesting to show.
    center window , pass through , window , windshield
    Tight steering Royster Original Mariah Talk 5 05-30-2013 04:40 PM
    There are 351 users
