Radio Bezel
Old 09-04-2016, 02:48 AM   #1
Scottie1961's Avatar
Scottie1961 is currently offline
Status: Gold Contributor
My Model: Z202 Shabah
My Engine: 5.7L Alpha One
Send Scottie1961:
Default Radio Bezel
My radio was wired directly to the ignition switch so it would turn off everytime I shut the engine off. Very annoying when playing from Bluetooth. Anyway, as I was rewiring the radio power I noticed the original bezel was in pretty bad shape. Looked like someone taped over the original radio opening and of course the little side tore when I was removing the bezel.
The radio was propped from behind with a metal strap wrapped around some wires. Not good so decided to beef it up a little. I made a draft of the bezel out of 1/16" diamond plate turned backwards. After polishing it really shines and looks pretty cool but doesn't really match the rest of the instrument panel. I still need to cutout for the dummy accessory switch and the blank engine shutoff hole and smooth the edges. It is rock solid and holds the radio without flinching.
I'm thinking about painting the aluminum diamond plate black but was wondering if anyone knows if the original sticker labels are available. My other option would be to find an original bezel piece. What are the chances of that? Anyway, I'm enjoying the new boat but wondered if you guys have had any luck with replacing these fragile pieces and opinions on using other materials. Also opinions on painting the aluminum if I can't find an original.
1995 Mariah Z202 Shabah
5.7 Alpha One Gen II
  • Old 09-04-2016, 04:32 AM   #2
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Default Re: Radio Bezel
    Ahhhhh.... You have a Z202... That's a little different than just a 202...
    The pieces that you're talking about were vacuum formed at the Mariah plant and are kind of rare. Not often do you see a Z202 being parted out....
    1998 202 Shabah 5.0L Alpha 1
    Phil Levine
    1998 202 Shabah
    Old 09-04-2016, 03:07 PM   #3
    pllevine's Avatar
    Send pllevine:
    I just saw another thread on this site about radio bezels for Z211 / Z212.... Not sure if it's the same as the Z202 but it looks pretty close. You might want to get the CNC file from them....
    Phil Levine
    1998 202 Shabah
    Old 09-04-2016, 08:59 PM   #4
    Send Scottie1961:
    Hey that would be great. I'll see if I can track that down. Thanks Phil!
    Old 09-08-2016, 08:57 PM   #5
    My Model: Z202
    Send Firestone:
    Mine is in need of replacing as well. Let us know how it goes!
    John
    Need measurements from radio bezel cswinings Original Mariah Talk 2 04-14-2015 09:02 PM
    Radio Bezel 272man Original Mariah Talk 11 06-04-2014 03:50 AM
    Wanted: talari radio bezel rew10 Mariah Parts For Sale & Wanted 6 08-05-2013 03:55 PM
    Radio bezel and sun deck repair tdmaker Projects 21 07-25-2013 11:45 PM
    Radio Bezel Template letnes Original Mariah Talk 2 09-24-2010 06:47 PM
    There are 189 users
