Led lights... big diffrence
Old 04-04-2017, 10:10 PM   #21
tpdtopcop's Avatar
tpdtopcop is currently offline
Send tpdtopcop:
Default Re: Led lights... big diffrence
Thanks for posting. I have a 1996 Z255 Shabah and was wondering what led's will fit in the cuddy?
  • Old 04-04-2017, 10:14 PM   #22
    tpdtopcop's Avatar
    Send tpdtopcop:
    Wonder what the difference between 5th and 6th generation is?
    Old 04-05-2017, 11:53 AM   #23
    elrack is currently offline
    My Model: z275st
    My Engine: 8.1L Bravo III
    Send elrack:
    It appears the 6th gen are brighter and 2mm longer.
    Old 04-05-2017, 05:08 PM   #24
    tpdtopcop's Avatar
    Send tpdtopcop:
    will they fit then or not?
    Old 04-05-2017, 09:36 PM   #25
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    They don't fit
    Phil Levine
    1998 202 Shabah
    Old 06-04-2017, 10:17 PM   #26
    tpdtopcop's Avatar
    Send tpdtopcop:
    Originally Posted by Hunter12345 View Post
    Are these the ones?
    '98 mariah shabah 180
    5.7l 350 mag
    Bravo III
    I put these in cuddy and not one of them worked. I then replaced one the the curtesy lights by rear seat and it would not fit in the holder all the way. Anyone else had this problem?
    Old 06-05-2017, 12:23 AM   #27
    My Model: Z202
    Send Firestone:
    Ugggg. Let us know what you end up with. LED lights are my next upgrade
    John
    Old 06-05-2017, 12:51 AM   #28
    pllevine's Avatar
    Send pllevine:
    I had that VERY issue. The LED arrayed light bulbs would not fit in the stock fixtures because they were too long.....
    So, with a sigh, I ordered new LED based 194 bulbs that are the same length and shape of the standard 194 bulb....
    If the bulbs that you bought wouldn't light up, then you should turn the bulb 180 degrees.
    Firestone and ROY850 like this.
    Phil Levine
    1998 202 Shabah
    Old 06-05-2017, 12:21 PM   #29
    tpdtopcop's Avatar
    Send tpdtopcop:
    Thanks for the reply. What LED based 194 bulbs did you end up going with?
    Nav Lights mhmariah Introductions 1 09-04-2014 09:05 PM
    Bow NAV lights Brody General Maintenance 3 10-10-2013 09:25 PM
    nav lights and gauge lights not working lumbercitybravest Original Mariah Talk 5 08-13-2013 05:11 PM
    bow lights? spot lights? need some help... with night time navigation nglauer Original Mariah Talk 13 07-09-2011 06:36 PM
    Got to have lights!!!!!!!!!!!!!!! paulbroeder Original Mariah Talk 28 07-20-2009 01:23 PM
    Total Members: 18,990
    Total Threads: 13,324
    There are 316 users
