1995 z275 water in bilge
Old 05-26-2016, 01:39 AM   #1
Zdeb0001 is currently offline
Send Zdeb0001:
Default 1995 z275 water in bilge
So the last 2 times I've had the boat out after pull the boat out When I pulled my drain plug I get about a gallon of water that drains out. I've searched everywhere in the bilge and can't find any water leaks. Anyone have any ideas or common issues with our boats. Thanks guys.
  • Old 05-26-2016, 11:44 AM   #2
    Brupa's Avatar
    Brupa is currently offline
    Status: BJL716 Z245
    My Year: 2002
    My Model: 2002 Z245 STC
    My Engine: MX6.2L BRAVO III
    Gallery Images: 12
    Send Brupa:
    Default Re: 1995 z275 water in bilge
    Gimbal ring swivel pin seal, possibly
    Thank you Brupa for this useful post!
    msmith68 (05-26-2016)
    Old 05-27-2016, 03:02 PM   #3
    My Model: Z276
    Send Brian Belcher:
    That's where my Z276 is leaking from. The gimble swivel pin seal.
    Old 05-27-2016, 03:45 PM   #4
    Send Zdeb0001:
    When I cut the shrink wrap off at the beginning of this season i had my drive off along with the gimble ring, bellows and swivel pin. I replaced the swivel pin seal, swivel pin itself, stainless u bolt, bellows, driveshaft bellows retainer ring and used a new drive install kit. I'm wondering if one of my bellows didn't seal?
    Old 05-29-2016, 06:42 PM   #5
    My Model: Z276
    Send Brian Belcher:
    Zdeb0001, I put the plug back in mine and got the boat as level as possibe. Than, started filling her up with the water hose. I found a thru hull fitting with a leak. Then, I took the hose and sprayed in the area of the tillar arm/swivel pin from the inside and found the seal around the swivel pin was toast.
    Old 06-04-2016, 02:22 AM   #6
    tpdtopcop's Avatar
    tpdtopcop is currently offline
    Send tpdtopcop:
    Wait your not supposed to have water come out after pulling the drain plug?
    Hello! new 1995 Z275 Davanti owner secondwind Introductions 4 03-25-2015 02:32 PM
    4.3L Oil in the Bilge but no water in oil dwymer64 Mercury MerCruiser 7 06-09-2011 12:54 AM
    Z275 Bilge Blower question csterner Mercury MerCruiser 8 04-14-2011 01:46 AM
    1995 Z275 and Chariot Trailer 272man Original Mariah Talk 2 02-26-2008 01:33 PM
    Water in bilge .. good or bad? 180diablo Original Mariah Talk 6 10-07-2007 05:44 AM
    There are 257 users
