Top speed
Old 06-09-2018, 03:07 AM   #21
jjt1276's Avatar
jjt1276 is currently offline
My Model: Shabah 202
My Engine: 5.0L with Alpha 1
Send jjt1276:
Default Re: Top speed
Update...two years later! Finally got around to getting the 60lb actuators for the smart tabs SX. I am running hole 3 and this seems perfect for light to mid loaded boat (Shabah 202 5.0 Merc). Prop is a 14x19 four blade. Top speed is mid to low 40’s depending on load. Not super concerned with top speed, we live on a smaller lake and we use the boat for water sports and lower speed cruising.
ian dewhirst likes this.
  • Old 01-26-2021, 01:10 AM   #22
    globa1950 is currently offline
    My Model: z222
    My Engine: bravo 3
    Send globa1950:
    hi guys. please help. i need advice
    i have 2 propellers but i would like to remove one and to try ride the boat with one.
    is it safe? will it not harm engine itself? I have mercruiser bravo 3.
    also if i remove one propeller- will it be okey for that metal beam that is sticking out from the lower unit( propeller holder)
    Old 01-26-2021, 01:29 AM   #23
    Im going to start off with this is a horrible idea. Not that someone somewhere has not done it, maybe in a pinch? Those are very expensive units to play with. Check the used prices on eBay.
    What exactly are you trying to achieve? Less efficiency? Less maneuverability? Higher top speed? The B3 is more efficient and maneuverable than a single prop. Small price to pay for a few mph off your top speed.
    Also, this might get more responses in "prop talk"
    Old 01-26-2021, 12:55 PM   #24
    My Model: z222
    My Engine: bravo 3
    Send globa1950:
    I noticed when i go full speed and bring up my trim for better smoother sail and fast speed,. Outer propeller comes out of water and doest allow for trim to be up as much. So basically i can hear it spinning out of water. So I wanted to know if I remove outer propeller- in order for plane speed trim up performance.
    Old 01-26-2021, 05:59 PM   #25
    Where do people come up with these ideas?
    No, its not a good idea to remove one of the props on a Bravo 3 outdrive. The outdrive was designed to be efficient & balanced with 2 props operating at the same time. If you are that worried about driving at top speed, switch out the outdrive for a Bravo 1 or install a pair of Smart Tabs which provides some lift to the stern and will allow you to keep the outdrive trimmed down a bit.
    globa1950 (01-31-2021)
    Old 01-26-2021, 09:13 PM   #26
    How exactly are you trimming the outdrive up? I know that might sound silly but if you are trimming up with the trailer (square button) it will allow your trim to go up to trailer height. If you are using the actual trim toggle the outdrive should not be running with the rear prop that high. Basically the trim limit switch allows you to operate the drive in a certain range without the trim coming up too high.
    You may also want to have a look at the spacer where the rams mount to the outdrive.
    Old 01-31-2021, 11:12 PM   #27
    My Model: z222
    My Engine: bravo 3
    Send globa1950:
    not with a trailer. out in the water. im used to bravo 1 . with 2 propellers(bravo 3) - icant jack up the trim up as much.
    220 Talari Top Speed LunenburgRider Original Mariah Talk 1 07-23-2013 02:37 AM
    Estimated top end speed??? suja415 Original Mariah Talk 25 05-04-2012 04:19 PM
    No Speed Lay Lake Mark Introductions 0 08-05-2010 12:47 AM
    top speed southcoastpower Original Mariah Talk 3 06-29-2010 09:30 AM
    speed and rpm jktbea Original Mariah Talk 7 05-20-2008 03:51 AM
    There are 313 users
