engine cuts out
Old 06-21-2016, 02:59 AM   #11
vern is currently offline
My Model: Z210 Talari
My Engine: 350 Alpha One
Send vern:
Default Re: engine cuts out
Hello
The pick up is a long plastic tube. It did not appear to have any cracks or holes...
could it be something on the bottom of the tank that gets sucked to the tube, then
when the motor stops, it floats away?
  • Old 06-21-2016, 11:20 PM   #12
    My Model: Z276
    Send Brian Belcher:
    Without a doubt, that's a possibility BUT, playing devils advocate, fuel level would not affect (effect?) that. Could fuel level just be a coincidence? Didn't you say that swerving would make it less severe ?
    Dude, I wish u lived in central Arkansas. I'd come over and help you.
    Do you have an engine oil, through the dip stick style pump ? I'd try to connect to the pick up unit with it still attached to the tank. Start pumping/ducking and see what comes out or better yet, if it stops sucking, which wouldn't suck.
    Sorry
    Old 06-25-2016, 02:36 AM   #13
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Mine was stalling at 3000 rpm. Turned out to be a loose wire on the fuel pump circuit that stalls the engine if the oil pressure drops.
    Old 06-25-2016, 03:16 AM   #14
    Send vern:
    i have a manual fuel pump..Do you?
    Old 06-25-2016, 04:07 AM   #15
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    1995 4.3 2bbl
    Sent from my XT901 using Tapatalk
    Old 06-28-2016, 02:07 AM   #16
    Send vern:
    hello
    where was this wire located?
    Old 06-28-2016, 03:31 PM   #17
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    Don't know. My boat mechanic worked on it. I'm skittish about working on gasoline related items.
    Old 06-30-2016, 01:12 AM   #18
    My Model: Z276
    Send Brian Belcher:
    I wonder if he's talking about the anti diesel valve?
    Old 08-06-2017, 01:25 AM   #19
    My Model: Z276
    Send Brian Belcher:
    What ever became of this?
    Radio cuts out at higher volumes Smokymance Original Mariah Talk 14 08-12-2014 05:57 PM
    Radio Cuts out bnussbaum Original Mariah Talk 8 09-12-2009 12:09 AM
    There are 338 users
