Water coming into boat from transom
Old 07-14-2015, 12:10 AM   #1
treedawg is currently offline
My Model: 180 Talari
My Engine: 4.3LX,
Send treedawg:
Default Water coming into boat from transom
I have been at the lake for the last 2 weeks and it rained every day . I noticed water in the bilge I assumed it was rain run off since boat always stayed dry. Than one evening I heard water pouring into hull , I ran up to the house and had wife follow me up to the boat ramp to drop off truck and trailor 20 mins later I was back at boat ready to go the ramp to get it out of water ( didn't want to sink it !) I checked for the water leak , could not hear it but seen small amount coming from on top of drain plug .before it was pouring in from somewhere ( really hard to see back there) when out of water I checked the bellows on shift, U-joint ,exhaust . I didn't see anything ripped or broken . I am not sure what my next step is going to be. I would like to know what part is bad before tearing outdrive down . DOES ANYONE HAVE ANY SUGGESTION I WOULD LOVE TO HEAR THEM . FATHER-IN-LAWS NEW PANTOON SAVED ARE VACTION .
KEVIN E.
  • Old 07-16-2015, 03:53 AM   #2
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Default Re: Water coming into boat from transom
    On my 95 Talari, I had water start coming in. Turns out one of the exhaust flaps had come loose and settled in the Y of the exhaust pipe where it eventually wore a small hole in the exhaust right below the waterline. I was told it was a problem with Mercruisers at that time. Had to pull the engine to weld the hole shut.
    Old 07-16-2015, 09:52 AM   #3
    bob-the-boater is currently offline
    My Model: 180 Shabah
    My Engine: 4.3L Alpha 1 Gen 2
    Send bob-the-boater:
    180 Shabah, 4.3L. Small trickle was from the shift shaft bellows. I use my cell phone to take pics/video of hard to see places.
    Old 07-16-2015, 12:27 PM   #4
    mariahshabah is currently offline
    My Model: Shahbah
    My Engine: 302
    Send mariahshabah:
    I know you checked the bellows but that was my problem on a 94. Maybe look at the bellows when the stern drive is both up and down. If you could put the last half of the boat in the water on the ramp and than take notice of any difference when drive is up or down. Maybe use a telescoping mirror and flashlight to help you see.
    Old 08-01-2015, 04:26 PM   #5
    GREG BUCK is currently offline
    Send GREG BUCK:
    Is your drive a merc bravo 3 duo prop
    Old 08-03-2015, 12:46 AM   #6
    My Engine: 4.3LX,
    Send treedawg:
    I found water leak , It is the SHIFT BELLOWS . My next question is can I just replace the bellow are do I need to replace the shift cable ?
    KEVIN E.
    Old 08-03-2015, 02:12 AM   #7
    My Model: Z258
    My Engine: 7.4 & Bravo 3
    Send 99 Mariah 258:
    You can change just the bellow but you have to take off the drive so probably should do the gimbal and replace the other bellow as well
    Thank you 99 Mariah 258 for this useful post!
    treedawg (08-05-2015)
    Old 08-04-2015, 12:06 AM   #8
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I second Mariah 258's suggestion. I have heard but never tried to fill the shift bellow with silicon from the inside as a temporary fix.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-06-2015, 02:11 PM   #9
    May as well do the other bellows and gimbal bearing while you're in there... Take it off once, replace the replaceable items and have no worries. If you are mechanical and have a set of tools it can be done for very reasonable.
    Thank you Motoxxx43 for this useful post!
    treedawg (08-07-2015)
    Old 08-19-2015, 01:02 PM   #10
    lumbercitybravest's Avatar
    lumbercitybravest is currently offline
    My Model: 225 davanti
    My Engine: 5.0l alpha
    Gallery Images: 4
    Send lumbercitybravest:
    Doing this as we speak. Almost similar circumstances as well. Pulled into our slip and the bilge kicked on (auto float) after a dry day of boating. Turns out the Bellows were bad. Doing All Bellows, Gimbal bearing and trim limit and sender switches While the outdrive is off. If you do the Gimbal, make sure the Zerk fitting and the hole in the bearing line up so you can pump grease in it each summer....
    Thank you lumbercitybravest for this useful post!
    62 driver (02-29-2016)
    boat been out of water mashymariah Introductions 1 04-27-2014 04:31 AM
    Water passage blocked in transom kutzcb Original Mariah Talk 2 09-20-2012 01:11 AM
    Boat Taking in Water Dsg03svt Original Mariah Talk 10 07-17-2012 03:02 AM
    New (to me) boat taking on water KeepitReal Mercury MerCruiser 2 07-25-2011 12:30 AM
    Water in boat? duketter Original Mariah Talk 10 06-14-2010 03:44 PM
    There are 248 users
