Dual battery question
Old 06-14-2015, 01:04 AM   #1
tpdtopcop's Avatar
tpdtopcop is currently offline
Send tpdtopcop:
Default Dual battery question
Have dual setup on my 96 Z255 don't know if factory or original owner put in. I have switch that says 1, 2, off and both. Now boat starts fine on 2 then when I switch to 1 it barely turns over and also when I set to both it barely turns over. Now if battery 1 is low would it barely turn over if switch was on both? What can I look for to check if they are set up right? Also what volts should boat be showing while running? Mines bounces between 12 and 13? Thanks for any input
  • Old 06-14-2015, 07:33 PM   #2
    tpdtopcop's Avatar
    Send tpdtopcop:
    Default Re: Dual battery question
    Update I put my dads boat batteries in which are fully charged and have same problem so any more info would be appreciated
    Old 06-15-2015, 01:49 AM   #3
    My Model: Z258
    My Engine: 7.4 & Bravo 3
    Send 99 Mariah 258:
    Clean the grounds and/or replace end connector's.
    Old 06-15-2015, 04:54 PM   #4
    tpdtopcop's Avatar
    Send tpdtopcop:
    Ok before it started to rain yesterday I cleaned the connections at the starter so my next cleaning will be at the duel battery switch. You think I should just change all connections with new while I am at it. Also my marine batteries are only 550 cca so i know a friend who owns a battery store and he's letting my try a couple of 1000 cca batts to see if that helps the problem.
    Dual Battery System twospeed46 General Maintenance 6 06-18-2018 02:46 PM
    Dual Battery Set Up firebirdzig Original Mariah Talk 1 03-30-2010 12:55 PM
    Dual battery Jbetschart Original Mariah Talk 5 11-04-2009 04:37 PM
    dual use battery? pimpadelic Original Mariah Talk 1 08-11-2009 02:15 PM
    There are 320 users
