98' 210 floor replacement
Old 05-05-2015, 03:21 PM   #1
CJ-performance is currently offline
My Model: 210 Shabah
My Engine: 5.0L Alpha 1
Send CJ-performance:
Default 98' 210 floor replacement
Has anyone replaced a floor on a 1998 Shabah 210? Are the floors glass or wood on them. I'm going to go look at one that according to the seller needs a floor (this is what is marina told him) but he has no idea what the floor is made of...
  • Old 05-11-2015, 02:56 PM   #2
    cptbraine31's Avatar
    cptbraine31 is currently offline
    My Model: 221 Talari
    My Engine: 5.7 Mercruiser
    Send cptbraine31:
    Default Re: 98' 210 floor replacement
    If I am not mistaken (someone correct me if I am wrong) but it is all fiberglass hull, wood stringer (fiberglass overlay), and fiberglass flooring
    Turn your blower on 5 minutes before starting or while idle, if not, BOAT GO BOOM!!!
    Old 05-11-2015, 04:03 PM   #3
    mark43 is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7L Bravo III
    Send mark43:
    If you have glued in carpet, the main part of the floor is plywood. it is approximately 4ft wide and runs to the bow. On either side of the plywood, the floor is fiberglass and there would be no way to replace that unless you took the entire boat apart as it is part of the fiberglass stringer system.
    Old 05-11-2015, 04:23 PM   #4
    Thanks I will be checking it out this weekend.
    Old 05-19-2015, 04:49 PM   #5
    So it turns out the floor is fine (all fibreglass). The issue is the hull is cracked about 8-9" up from the keel on both sides (first chine) in the ski locker area (about where your feet sit). Looks like it's an old repair that has failed again.... From what I see the marina stores the boat on a wood racking system and it was dropped on that spot. This was probably the reason for the first repair 10-12 years ago (has been stored at the same marina since new). I've looked over the rest of the hull and it looks solid, can't find any other stress cracks or damage. Has anyone repaired the hull on a 1998? I've done stringers, floors and transoms before so I have a pretty good idea what needs to be done. I believe I can remove the center section of the floor cause it looks like it is screwed in. Then cut out the old repair and make my new one between the fibreglass "stringers" inside the ski locker... Any ideas or input?
    pics of 97 221 talari floor replacement and full interior replace dafucwuzat Projects 14 06-12-2018 06:50 PM
    1993 diablo floor denn69 Original Mariah Talk 7 02-13-2012 01:39 AM
    Floor Sink? jmorgan Original Mariah Talk 8 12-10-2011 12:34 AM
    Floor repair / replacement karmann Original Mariah Talk 1 06-05-2009 10:30 PM
    Floor Provo Projects 7 03-26-2009 07:28 AM
    There are 362 users
