Draining tilt,trim,fluid reservoir
Old 05-07-2010, 05:22 PM   #21
1stDave's Avatar
1stDave is currently offline
My Model: Z275 Shabah
Gallery Images: 3
Send 1stDave:
Default Re: Draining tilt,trim,fluid reservoir
I just completed the same procedure on my Z275. The problem seems to be rainwater entering the the filler cap.
When I parked my boat at home for winter it was tilted to starboard. Water filled the ledge under the engine hatch and overflowed onto the trim assembly. I used my Oil vacuum pump to suck out the bad oil-water mix.
Tested trim up and down about 10 cycles after refilling with fresh 10W30.
Oil got a little milky so I sucked that out and tried again. One the third time the oil stayed clear.
I'll make sure that the whole boat is covered this winter. I may also install drains at each corner so water goes directly into the bilge. (my boat is not covered in summer).
Just a thought.
Thank you 1stDave for this useful post!
MPG (05-19-2021)
    Prop Trim Button PouredOut General Maintenance 9 07-03-2008 04:57 AM
    Trim trouble shilo Sea Fox - Mariah Talk 5 02-20-2008 02:24 PM
    Wanted: Trim gage and head light designbygeorge Mariah Parts For Sale & Wanted 4 11-17-2007 02:02 PM
    trim trouble aquaknot Original Mariah Talk 5 08-13-2007 12:17 PM
    Fluid question. KSP181 Mercury MerCruiser 3 08-01-2007 03:11 PM
    There are 306 users
